Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic PT 51HX41E flickering colors
Model: Panasonic PT 51HX41E
Chassis: AP820
Work done: Replaced (2) STK392-110 with (2) STK392-150
Issue: Sporadic flickering colors
I replaced the 2 convergence ICs, thinking it would be a quick fix, but to no avail. At least I upgraded from 110's to 150's! A previous tech had suggested that it was the "color board". TNPA2033S is the DH-board he refers to. The issue at hand is that the screen shows mostly black and white, with sporadic flickers of colors in various places at any given time. Customer refers to it as "psychadellic". When I reference this part in the SM, it says that it controls PIP PROCESSING, SPLIT, SEARCH, and
Question: Has anyone had similar experience with this issue, and is this part the culprit? If not, any further suggestions?
  • 38 Answers
Ok her is a good test for u, bring up the pip on screen and see if the picture is the same as the main picture if at is it sounds like to me that u have a bad pip board that is causeing your problem u can bypass the pip u just need to jump the video in to the video out and sync out and in and remove the pip most of time i have found that the small caps go back on the board and u lose snyc and that is y your picture goes black and white with blinking color in the background. now the stk392-150 is a better chip then what u had in it but convergence problem has nothing to do with color snyc. i hope this will hp u marty
Posted on Oct 13, 2008
I have a Panasonic PT-51HX41E, and it will not power on.
does the power light blink? If so thats an error code let me know the number of blinks and I will assist you with the issue.
Feb 06, 2013 | Televison & Video
I have a panasonic PT-51HX41E 52" projection tv
A tech might be able to get into the hidden tech menu---sub brightness and sub contrast settings are there and it is not real easy to get into and does vary from model to model---access is with the original remote.
A suggestion if you can not or do not want to pay would be to search with Google and the model number for a "Service Manual" which will in it have instructions and indicate how, it will also have a list of items in that menu---be careful what you adjust there.
Dec 14, 2012 | Televison & Video
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My panasonic pt-51hx41e will turn on for couple secs then turn off
hello. it sound like a power supply problem.!!! to me .!!! you can check it frist.!!!"good luck"
Aug 01, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt51sx60a ,bottom of picture bowed color has shadowy hues of blue ,occasional warping of picture ,hard to watch
my tv is panasonic pt-51hx41e hay can see picture but come on disturtion in tv ,they side that is mother board $380.00 hay need to now is true,or hay can buy part and ware?
Jul 30, 2008 | Televison & Video
Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Problem is double lettering PT-51HX41 51
What is the resistor location as shown on board.....for instance,
Oct 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Need help,pc board panel (CIRCUIT BOARD)
This board is no longer available from the manufacture my friend, BUT DON'T Fret! It is available as a rebuilt board from a firm called PTS corp, and they are located at or it might be best to call them at 1-800-844-7871 Good Luck
Jun 03, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
242 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
