Question about Nortel i2004 IP Phone
Nortel phones abroad lose their feature keys
I have a handful of remotely connected Nortel IP phones that intermittently lose their "Feature Keys" however they retain their voice capabilities. Resetting the phone by pbx or recyling does not fix the problem. Only by going into the signaling server and resetting the features for that specific phone seems to do the trick. From an IP perspective what criteria must be met to ensure proper operation of the phone feature keys? Is there another signaling protocol that must be given a certain level of qos outside of the call signaling and voice streams that controls these features? I'd appreciate any help.
3 Suggested Answers
  • 7 Answers
SOURCE: Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Posted on Feb 13, 2008
  • 8 Answers
SOURCE: Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Posted on Jun 26, 2009
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
How to forward call to another phone
Press feature soft key (first button under display panel) and the 4.
In order to cancel call forward press feature key, # key, 4.
Jun 23, 2012 | Nortel Business Series Terminal T7208 -...
How to programe the 14 button on the m3820
When you connect a Nortel Meridian M3820 phone to a 3300 CITELlink Gateway andprogram it as a CITELlink Type2 device, ... Button Label. Function ... Feature Key 4. 11. Feature Key 5. 12. Feature Key 6. 13. Program. 14. Menu Right
May 07, 2011 | Nortel Meridian M3820 Corded Phone
I cannot change feature key labels on an i2004
I had to change the name under Lines on the Unified Manager.
Nov 05, 2009 | Computers & Internet
How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Nov 04, 2009 | NorStar T7316E Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
How to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Jun 23, 2009 | Nortel 2002 IP Phone
How do you do a call pickup on Nortel i2004 system?
Feature 75 if the phone is in your group (see administator), Feature 76 plus DN (extention) to use directed pickup (if you know which extention is receiving a call)
Mar 06, 2009 | Nortel i2004 IP Phone
Dec 18, 2008 | Nortel 1140E
T7316e Nortel Meridian Norstar Telephone
Feature *1, Press the desired key, dial the #
Nov 03, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel i2004 IP Phone Logo
90 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
