Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman generator 4000
Where can I find an off/on switch
    Problem Solver:
  • 13 Answers
Powermate went out of business , but here is a website http://www.powermate.com/contact.php
you can probably get a off/ on switch at your local small engine repair shop. it probably can be any switch for a gen.
Posted on Sep 28, 2008
Looking for wiring diagram for my coleman powermate PM54-4000
http://www.powermate.com/productmanuals.php?cat_id=3
May 07, 2016 | Coleman Electrical Supplies
Coleman 4000 4000 problem starting starting
Your question is a little vague.
There is a process of elimination.
Spark, fuel, and compression.
Sep 14, 2014 | Electrical Supplies
I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
May 07, 2010 | Coleman Electrical Supplies
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Where can I get parts for Blue Max 6.5hp blue max
http://www.powermate.com/productmanuals.php?cat_id=3 for manuals and parts diagrams
Mar 16, 2010 | Coleman Powermate Powermate 5000W...
Coleman powermate 4000 pops circuit breaker on the 220 side.
Don't know what you mean by "on the 220 side".
The generator has two joined circuit breakers that each are 110 volts. Between the two is 220.
If just one of those is opening WITH NOTHING PLUGGED IN, then there are only a few explanations.
1. There is a short in the wiring or the wiring has been tampered with and connected incorrectely.
2. The switch that switches the mode from 120 to 240 has gone bad, possibly with a welded contact. This would occur if the switch is changed with load on the generator. This could put a driect short on half the generator winding and cause one of the breakers to blow.
3. Worst is a winding short in the generator. Fortunately this is the least likely.
4. The 220 receptacle has been broken and insulation failed shorting one terminal to another.
Nov 14, 2009 | Coleman Powermate Premium Plus 6250W...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
718 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
