Question about JVC RX-552V Receiver
Help I can not connect the rear speakers to work and i can't find the manual and lost my remote. Can you please help me connect all the speakers to work.
Center modes, rear levels,
Posted on Feb 09, 2009
I Lost My Samsung HT-D355k Home Theater's Remote & Now Surroud Speaker & central speaker is not Working. help me what should i do?
Get a replacement remote of a substitute to help you select menu items. Otherwise try to navigate the menu using the buttons.
Check this site to get manuals for this product.
HT D355K HT D355K ZN Support SAMSUNG Gulf
Feb 09, 2015 | Samsung Audio Players & Recorders
How do I get my control to work with my bose speakers
I have to guess on this one, so bear with me. If you have audio out connectors on the rear of the TV, connect your speakers to them, then go to setup on your remote and turn off the TV speakers. After that, you should hear TV sound only from the Bose speakers at whatever level you set
Oct 03, 2012 | Panasonic VIERA Televison & Video
How do i connect my klh bassbite V subwoofer to my sony receiver model str de335?
http://www.docs.sony.com/release/STRDE335.PDF
I am basing hookup on my Bassbite !! manual. The procedure should be the same as on your Bassbite V
I have given you a link to your Sony Owner manual. It looks like you will connect your sub to the sub output on the rear of your reciever using the rca cable. Woofer out on the Sony to the R/Mono input on your Bassbite. If you have the front and rear speakers hook your rears into the rear speaker outputs then connect your front speakers to the front speaker outputs of your Sony. Your speaker jacks on the Bassbite will not be used for this configuration.
Now, adjust your speaker size setting for "SMALL" or "LARGE" speakers as appropriate for your setup (this is for the front and rear speakers and will not effect your Bassbite). Now set your Sony subwoofer output to "ON" You access this setting through your menu. That should be located on your remote for the Sony. You will want to refer to the manual to find the exact method to access your system menu.
If the link to your manual doesn't work for you then go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE335 and click on Operating instructions.
Hope this helps. Let me know okay? By the way, if this works for you you should be very pleased with the sound quality :-)
Kindly, DAVID (sean1dave)
Feb 26, 2011 | KLH ASW10-120 Subwoofer
Lost wiring diagram for sony cdx-gt170 please help, which are speakers and power etc, cheers
Red=Power (from radio fuse)
Yellow= Constant Power (battery)
Black= Ground
Blue= Remote (power antenna)
The speakers are a little foggy to me (sorry), but I do know fronts and backs, just not 100% on left and right.
Purple/Purple and Black= Right Rear
Green/Green and Black= Left Rear
White/White and Black= Left Front
Grey/Grey and White= Right Front
Hope this helps!
Aug 05, 2010 | Car Audio & Video
JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Sep 18, 2009 | Car Audio & Video
Output picture for KORYO KHT 4000 Home THeatre
I want remote of koryo kht 4000 hometheatre
May 15, 2009 | Audio Players & Recorders
No sounds through sub and rear speakers
Your radio probably has a sub on and off function on it that was reset when it lost power. Go into your setup menu to turn it on.
Oct 21, 2008 | Car Audio & Video
For my logitech z-4 speakers, my right speaker works fine but my left speaker has stopped making noise. if you turn it up to maximum you can slightly hear it, but its really quiet. can i fix it?
googled the same exact prob. and found this forum. after reading through the postings to get some ideas, I went back to my speaker set and unplugged the serial port that hooks up to the remote. blew on the connector and plugged it back in and VIOLA! I got sound from the left speaker again! Must be my awesome, smelly breathe that woke up the left speaker....
May 31, 2008 | Audio Players & Recorders
Codes for Universal remote for a Durabrand speaker system
You will need the manual. Probably have to hold Menu or a combination of buttons for a couple seconds and punch in the appropriate code for your device. You can find just about any manual online...just google everything you know about the remote and look for a manual pdf or something. Good luck!
Dec 24, 2007 | Durabrand HT-3915 System
182 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
