Question about Nortel 2002 IP Phone
Feature Keys disappear
I have a handful of remotely connected Nortel IP phones that intermittently lose their "Feature Keys" however they retain their voice capabilities. Resetting the phone by pbx or recyling does not fix the problem. Only by going into the signaling server and resetting the features for that specific phone seems to do the trick. From an IP perspective what criteria must be met to ensure proper operation of the phone feature keys? Is there another signaling protocol that must be given a certain level of qos outside of the call signaling and voice streams that controls these features? I'd appreciate any help.
3 Suggested Answers
  • 7 Answers
SOURCE: Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Posted on Feb 13, 2008
  • 8 Answers
SOURCE: Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Posted on Jun 26, 2009
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
We have new phones, not sure how to do call pickup
  • Feature 75 or
  • Feature 76 plus the extension you need to pickup.
Mar 23, 2011 | Nortel i2004 IP Phone
How do i change the time on nortel t7208
Hi....you need to push "feature" button at the top of the phone, then * * 2-3-6-4-6 (a.d.m.i.n ), then when phone asks for password, press 2-3-6-4-6 again, default, unless someone has programmed a different one. use the template link below, this fits over the row of keys on the right side of phone. push "next" until you get to "date and time", and then with a combination of "show" and "change" you can get to change time . try it and see how it goes. email me at gpeter52@yahoo.com with questions. link is good for other commands as well. good luck
http://www.meridian-norstar.com/3_nortel_meridian_norstar_programming.html
Nov 08, 2010 | Nortel Business Series Terminal T7208 -...
CAN'T CONNECT TO WIRELESS PRINTER AFTER VPN TUNNEL CONNECTION
Check the IP segments. Your printer & your machine would be falling in the same IP segment as your job network. Change the IP segment of your pc & printer.
Sep 01, 2009 | Arris SURFboard SBG900 Wireless Router...
How to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Jun 23, 2009 | Nortel 2002 IP Phone
How do you do a call pickup on Nortel i2004 system?
Feature 75 if the phone is in your group (see administator), Feature 76 plus DN (extention) to use directed pickup (if you know which extention is receiving a call)
Mar 06, 2009 | Nortel i2004 IP Phone
Dec 18, 2008 | Nortel 1140E
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
here you are...
Jan 10, 2008 | Nortel 1140E
Bsr222 tunneling problem
What are you connecting into the bsr at distant end, lap top or ip phone
Dec 28, 2007 | 2wire (1000-400108-001) Router
Nortel 2002 IP Phone Logo
50 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
