Question about Home
Leak in the shower is leaking water through the ceiling
When we use the shower, water leaks through the ceiling.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi lorenzotwalk,
I'm Harvey the Master Plumber.
Your problem is: When you use the shower, water leaks through the ceiling.
First, since it only leaks when you're using it you can ignore the water lines. Now comes the detective work. Look very closely at any place the water can squeeze thru, i.e. cracks in grout or caulk, etc. Don't forget to look on the floor imediately outside the shower and around the shower door if any. If found it must be scraped out, cleaned and dryed to get good adhesion, then caulked with a high quality silicone caulk (color of your choise). Any other caulk will crack no mater what they say.
Let dry for 24 hrs.
If you havent found this kind of problem it's time to look at the drain line connection. You may have to open the ceiling to do this, that's why I'm always carefull in the first step. Turn the water on and watch the drain connection. If it leaks there, it must be repaired. In this case you might cunsider checking the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 19, 2008
How do u know if u he a leaking pine between wall even if shower is turned off
I assume that you mean a leaking pipe. If it is leaking the water has to be going somewhere. If the shower is on the second floor then look for water stains on the ceiling of the room under the shower. If the shower is on the first floor go to the basement or crawl space and look for water signs there.
Oct 29, 2017 | Home
Ceiling mounted shower head (Danze) leaks water for a good 30-40 seconds long after being turned off
you really can not because of the overhead piping holds lots of water and so does this big head....that is just normal for these things...i am a licensed plumber for over 34 years and have done these...its just draining out all the overhead water....
Oct 06, 2012 | Danze Home
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
Leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Sep 26, 2009 | Home
Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Jun 18, 2009 | Heating & Cooling
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Mar 20, 2009 | Home
SInce it is wet both under and behind the shower I would rule out the drain floor pan and drain system and think it most likely to be the pipe leaking from the mixing faucets to the shower head. Find studs directly behind shower faucet, n each side. Locate the center of the studs and put vertical lines up and down on the center line of the two studs closes to but outside the shower  faucet on each side. Approximate 6 inches or so  up and down for the height of the shower faucet (Valve, not head) Put Horizontal lines across between the two line at both the top and the bottom/ You now have a square.Using a Razor knife(Sometimes called a box knife, stanley 99a for example) cut into the lines of the square back and forth as deep as you can. Cut an x  acrossthe square corner to corner again as deep as you can . Lightly hit the center of the x until the drywall caves in . Cut the remaining drywall out for the square. Now while  the shower is running you will be able to see whee the leak is. Use pipe seal after disassembling the loose fiting or repair the leak iun what ever manner is necessary. Replace and repair the hole made in the drywall  with another piece of drywall, tape and joint cement. .
Feb 27, 2009 | Home
Home Logo
2,316 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
