Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57ws510 convergenece prblem
I have sony kp-57ws510 with convergene problem.I found on the power board( G board) 2 pico (5Am) open and 2 cap C,5018,C5019 (1000uf-35V)had blew,I replaced (2 pico and 2 cap) and do some adjust with remote control the picture work fine ,but after 8 hour the problem happen again,and at this time only 1 pico 5Am( ps5001) on the G board dead and after I replaced, the pico open again ..agian ... 1 or 2 day .
pls.give any suggestion . thanks
  • kseuler Oct 25, 2008
    I have the same convergence problems, concave screen top and bottom, colors out of alignment on sides, and convergence doesn't work.  I replaced the STK IC's and still have the same problem.  Any other suggestions?
    Novelist:
    Champion:
  • 203 Answers
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Posted on Sep 18, 2008
  • Sony Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, pico fuses, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 26, 2009
Convergence repair kit used but problem is worse
did you check and replace the two pico fuses on the G board and also the six pico fuses on the D board? If so double check the solder often a pins mounting ring will lift up during the removal and prevent solder connection when doing the install.
Jan 01, 2013 | Sony KP-57WS510 57" Rear Projection HDTV
What are the specific pico fuses for my RPTV
The amperage is marked on the board right next to them--likely if they go to the convergence circuit they will be marked 5a or 5 amp.
Usually but not always there are more at the convergence chips.
I presume you did not look closely at the board where the two you found are---Sony marks everything.
Jun 15, 2012 | Sony Televison & Video
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
Hi,I have sony projection tv KP-57WS510 every subject apears threeple with colorful reflection.What to do? Thanks,Kris
You will have to install a convergence repair kit which will consist of both convergence ICs and the 8 associated pico fuses and the 4.7 ohm resistors will also need to be checked. Your model uses the Sony type 1 convergence kit. If you want to know where you get one they are available from www.tvrepairworld.com they do include the parts and the CD with repair instructions.
Jul 09, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57ws510 no power, standby on
Remove the rear cover and look at the board on the left hand side. It's the G board. It has the power cord going to it. Remove this board and on the it you should, with some effort, find D6116 and D6301 diodes. These just need to be heated up to re-melt the solder and then re-assembled. This worked for me anyways.
Oct 17, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Blue bowing convergence issue
did you check the two IC protectors on the G power supply board? Often they can blow when the ICs fail they are ps001 and PS002 they are brown 5 amp " Pico Fuses"
Mar 27, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Flashing light
Video output IC on either the CR, CG or CB pcb boards is most likely the problem or the A board is defective. I would try the video output on the CR, CG and CB boards first.
Jul 16, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Pico fuse
They are usually 3.5 amp picos depending on what circuit they are in. If you go to this link and leave a email with your model number and pico number such as PS321 they will tell you which rating you need and they have all picos for sonys instock.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57ws510
test your power supply output voltages, make sure the step down transformers are not leaking high voltage into the dc circuits. always start at the basics then work your way up or out. the most common problem for these late model tv's is power supply they just dont use quality parts anymore. in older tv's you could hear the high voltage arcs, snap today its rare for that to happen. I have a 32 inch LCD here now that actually blew a 1500 pico farad capacitor with no noise. that amazes me thats a pretty good sized capacitor, and they usually make some noise when they blow the top right off of them.
Nov 01, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57" Rear Projection HDTV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
