Question about Konica Office Equipment & Supplies
I replace the developer ,did a counter reset and L-detect comes oo5-- 025
    Sergeant:
  • 225 Answers
You forgot to set new Maintenace count.
Posted on Nov 03, 2014
2 Suggested Answers
  • 17 Answers
SOURCE: CODE f-26-2
pull out developing unit out and clean all connector of developing unit with contect cleaner
Posted on Oct 02, 2008
What's your question?h how can i fix m2 in konica minota 213 ineo copier
Reset the drum and developer counters to zero, the replace the developer, and run the required TCR adjustment. Do NOT reset the counters then think you don't have to replace the drum and developer, because the copier uses the counters to determine voltages for certain parts inside the machine, reset counter and not replace the parts the copier thinks they are new when in fact they are old you get codes and bad copies.,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 02, 2016 | Konica Office Equipment & Supplies
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Devloper reset code
Has the developer been replaced? If not reset code for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counter with out replacing the require item the copier will adjust certain voltages to certain items such as the drum and developer system as those there are new because you reset the counters when in fact he developer is old and so mite be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared and was the required F8 checked run?
Dec 15, 2013 | Minolta bizhub 200 All-In-One Printer
MAINTANANCE M2 MINOLTA BIZHUB 163
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old.
Jan 31, 2013 | Minolta bizhub 180 Black and White Copier
Minolta Dialta Copier Di152, code reads 32-COF
Replace the developer and developer unit. And Replace the drum normally done together make sure to reset the drum developer counters because the machine use the counters to set voltages to the drum and developer and it is the only way the copier knows it has a new drum and developer reset the counters without replacing the drum and developer causes code sand image problems
Sep 16, 2012 | Minolta Office Equipment & Supplies
We have a Minolta Di552 copier with an error message C-0F24 on the display panel. What is the problem?
Has the developer been replaced? If not reset counter for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items then the copier will adjust certain voltages to certain items such as the drum and developer system as those they are new because you reset the counters when in fact he developer is old and so might be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared !ST!!!!!!!!!!!!!!! and was the required F8 checked run? after installing. Also was the drum removed and the sensors cleaned by brush NO Vacuum cleaner. Static Electricty can destroy the the sensors.
Dec 22, 2010 | Minolta DiALTA Di350 Laser Printer
Mal function detected. please call your Technical Representative c2557
ATDC Sensor Failure
• The scanning value of the ATDC Sensor is less
than 7 % while the IU Motor is turning.
• The scanning value of the ATDC Sensor is more
than 19 % while the IU Motor is turning.
The sensor in the developer unit has failed. In some cases this code will occur after a PM where the developer was replaced and calibrated but the developer or drum counter was not cleared. The reset for this error is to turn the machine off (unplug it) and turn it back on. If the error comes back you will need to replace the sensor and developer.
May 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
CODE f-26-2
check your T/S and you CVR value
Sep 15, 2008 | Konica Minolta DiALTA Di200 Copier
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
23 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
