Question about Bissell Vacuums
Bissell flip-it won't dispense water/cleaner solution.
SOURCE: bissell pro heat cleaner
My Bissell did this same thing and it took forever for me to figure out. Seems one of my kids turned the dial that says heavy traffic, normal traffic around and around. All I had to do was turn it back until it wouldn't turn anymore and VOILA!
Posted on Sep 23, 2007
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: 9200 Bissell carpet cleaner, water will NOT dispense
The water or soap line might be clogged, or something is broken. If it is just the upright part and not the handle, then its a solenoid, if its both then either the pump motor or the pump is not working.
Here is a list of parts.
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
Hope this helps.
Posted on Jan 08, 2009
  • 61 Answers
SOURCE: Have a bissell pro steam cleaner the suction is
Use this guide!
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Troubleshooting_ProHeat2X_9400F.pdf
Posted on Apr 15, 2009
  • 29 Answers
SOURCE: Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Posted on May 29, 2009
Bissell 38B1-L - water from floor?
No, the Bissell 3 in 1 vac 38B1-L does not pick up water. Try the Bissell Flip It 5200. You can always call 1-866-GoVacuum for free answers when buying a new vacuum. - Justin Buy Bissell 5200 Flip It Bare Floor Cleaner Online at Best Price Hard...
Mar 05, 2014 | Vacuums
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hey, sorry to hear you're having problems with the spray.
Here's a quick link to troubleshooting steps to assist you.
Jan 30, 2013 | Bissell Proheat 2X Select Pet Upright Deep...
Soap won't dispense from tool sprayer
Here's a quick link to some helpful tips. http://www.bissell.com/FAQDetail.aspx?id=1064&cid=ccsocial
Here's a link to locating a BISSELL Authorized Service Center if you continue to have difficulty.
http://www.bissell.com/service-centers/?cid=ccsocial
Dec 01, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Have a model 9200 that is not dispensing fluid,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and cleaner dispenses from handheld attachment only
He could be right but most of the time when it doesn't dispense water and cleaner it means that the pump belt is worn and needs to be replaced. I would try that first (only $4.99) before I spent $100. Here is the pump bet you need, it comes with instructions:
Bissell 1699 Proheat Belts
Dec 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Won"t dispense water
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Vacuums Logo
69 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
