Question about Psion WORKABOUT PRO
Workabout pro wont turn on even with full charge
My workabout pro is fully charged and I turned it off, now it wont turn on.
  • Anonymous Nov 26, 2008
    rt f f
Make sure that the battery cover screws are in closed position. There is sensor that cuts power to device if battery latches are not completely closed.
Posted on Sep 30, 2009
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
My Nextbook model: NXA8QC116B wont turn on even when fully charged.
Unplug the battery and connect again might fix the problem.
Nov 04, 2015 | Cell Phones
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My camera wont turn on even with fully charged batteries
Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Samsung Digimax D53 Digital Camera
My garmin will not turn on and its fully charged
The reset button fixed the power problem. Thank You, Thank You!!!!
Feb 09, 2009 | Garmin nuvi 350 GPS Receiver
I charge my LG KU990 full over night within 12 hours the battery
You just have to charge it fully but not for long as soon as it turns full battery then swithch ur phone off then take the battery out for a sec then put it back on then turn ur phone on then it will work for a longg timeee kk..
Nov 13, 2008 | LG KU990 Viewty
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Psion WORKABOUT PRO Logo
570 people viewed this question
Top Psion Computers & Internet Experts
Lee Michel
Level 1 Expert
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
