Question about Kicker ZX650.4 Car Audio Amplifier
No sound output
My kicker kx650.4 does turn on but doesnt make any sound.i took it to a repirman but he has been unable to find out what is the problem with it.please let me kow what can be wrong.
  • 631 Answers
Have your technician email me and I'll try to help him troubleshoot the amplifier.
babin_perry@yahoo.com
Posted on Sep 18, 2008
I have 4 rsd65cs Phoenix gold 6.5 components 4ohm stable & 1 06S10L74 kicker I want to run it at 2ohm. A lil overpower is fine as I can always turn down.what is the best Option 5 channel amp? Thanks
sounds like you need to get a 2nd amp for the woofer, then bridge the two amps but be sure to adjust the output mode to lpf for your woofer and hpf for the 6.5s. hope this helps.
May 04, 2015 | Kicker Car Audio & Video
I had some kicker 6x9 cs693 installed in my 2002 camry rear deck and when they returned the car the spearkers are not producing much sound or bass. I am using factory stereo and also the factory 6x9 on...
first check to see that the fader is not programmed to the front speakers fading it rear might solve your problem, second if your stereo has a 4 ohm load requirement at the output and your new speakers are 8 ohms this will cut the power output in half, your best bet is to get an amp if these do not solve the problem.
Feb 27, 2015 | Kicker Car Audio & Video
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
800w sony amp
I know i had a similar problem in my car, i ended up needing to do a battery relocation to the boot and putting a bigger battery in. Dont forget that just because the physical size is big doesnt mean it it has the amps so read the battery!
Dec 04, 2013 | Kicker KX Series 04KX1200.1 1200w RMS...
Kicker SX900.2 turns on then says overload and shuts off
Sounds like one or more of the output transistors have gone and the amp protects itself from any further damage.
May 06, 2012 | Kicker Car Audio & Video
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
I've been running a kicker kx 800.2 and it has worked until now
Hello highryguy420,
It sounds like one or more of the output components is failing on the amp. You can contact Kicker support directly for instructions to return the amp for repair: support@kicker.com . Alternatively, if you have a local car audio shop that does component level repairs, they could perhaps save you some money and time.
Hope this helps.
Jul 14, 2009 | Kicker KX800.2 Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Rattling subwoofer
If you can smell burning I would say your voice coils are shot... My friend has a older Kicker subwoofer and it was doing the same thing you described... We took it in and the audio repair shop said it was toast.
Mar 28, 2007 | Kicker Solo-Baric S12L5 Car Subwoofer
Kicker ZX650.4 Car Audio Amplifier Logo
59 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
