Question about Mitsubishi WS-55819 55" Rear Projection Television
Back of tv
Is there a way to take the back off the TV so it can be moved to a basement?
    Problem Solver:
  • 18 Answers
Yes, start with unpluging the set. lol remove the lower rear cover first by removing all of the screws around the oustside edges, left-right-top-and next to the input panel. then remove all the screws around the edge of the top of rear cover. Be carefull because the top rear cover contains the mirror!! There is no way to make the bottom of the set any smaller other than removing the speaker grill in front. (usually this is just a snap-on cover.
Posted on Jan 04, 2009
Need to move a 57"
stand the tv on its end so it can go around the corner
Mar 16, 2011 | Televison & Video
Hi I want to move the TV to my basement. I
ON THE SIDES THERE ARE 4 SCREWS THE TOP LIFTS OFF
Dec 15, 2009 | Mitsubishi WS-65908 TV
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Moved, now can't get the TV downstairs
it went down the stairs in one piece it should come up the same way
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KV40XBR800
YOU MAY HAVE A BAD IC 2504 OR M BOARD EST $250.00-450.00
Sep 05, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony KP-53XBR200
check cable grounding, does it do it with a dvd?
Feb 01, 2008 | Televison & Video
1994 52in. RCA projection TV
Sounds like a solder issue either in the horizontal / Vertical deflection circuits due to the fall. I would check out the solder joints especially around the heat sinks. Hope this helps. If you provide the Chassis number for the RCA I can be better equipped to give you component locations to inspect.
Jan 25, 2008 | Televison & Video
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
