Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell proheat 2x
Cleaner was working but will no longer **** water
After disassembling the unit to gain access to the hoses, the electric valve and the pump, I was able to determine that the pump was not working. NOTE: If you plan to test if the pump motor is working or not you must first remove the belt that drives the brushes from its motor pulley. This is done by first removing the C-ring that holds the pulley on the motor shaft, then slide the pulley, belt with it, off the shaft.This will allow the motor to turn without spinning the brushes. With the unit plugged in and turned on, pull the cleaning solution/water trigger. The pump motor has a short shaft sticking out and it should spin. You can touch the shaft with a finger and feel if it is spinning or not. I have no idea if the motor can be purched separately or if it is available only with a pump assembly. I also have no idea if you can buy either. I reparied the motor, but I will not go into detail on this at this time. Sufice it to say that the shaft was in dire need of lubrication. Most people would not elect to disassemble the unit to the extent that I did and I would simply recommend taking it to an authroized service center.
Posted on Sep 18, 2008
Bissell PROheat 2X No longer sprays water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Oct 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro 2x the cleaner solution & water
heatman101
shg
Jul 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat 2x wont vacuum up water
There is a float (usually looks like a red ball) that rises up if water is in danger of getting to the motor. Sometimes they stick.. Give it a poke to free it up.
All the best,
WD
Aug 18, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
104 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
