How to use the CineDashMediaConsole on a ACER Aspire 8920
The light is on but nothing happen if i touch the pad ...
I can't find a way to put up or down the sound !!
  • serge_ss2001 Dec 24, 2008
    same problen on 6920g
Every now and then, the CineDash media console on the Aspire Gemstone Blue models freezes, turns off, refuses to work, leaves you in locked out of the car in the pouring rain… The causes are endless, but the solution is quite simple.
To reset the CineDash, remove the power cable AND the battery for more than ten seconds.
Tadaa!
Posted on Jan 09, 2009
Need operating program 4 cinedashmediaconsole acer 8930G
Posted on Jan 27, 2010
My touch pad works with a mouse,but when I tap my touch pad nothing happen's,thats when I lef click my mouse,it will move the icon,but wont tap on toanything
This has happened to me and it took me hours to figure it out. I hope yours is the same problem...
Make sure you dont have your touch pad set to off. On my ASUS It is F9 on my keyboard. the key shows an icon of the touch pad with a slash (/) through it. If you do not see this on your keyboard try looking in control panel and see if there is a setting in there. Good Luck. Please let me know if this worked.
Geraldine
Nov 18, 2011 | Computers & Internet
The pots and pans and the normal light blinks but nothing happens
most likely you have a bad touch pad,you can first try this,shut the power down to the dish washer,open it up and unplug the ribbon from the touch pad that goes to the control board,unplug it off of the board for 5 minutes and then reconnect it the same way it came off and then run it and see if it repaired it,if not you'll need a new touch pad.hope this helps,one more thing,on the back of the kickplate or bottom panel has a tech sheet on the back of the panel,you can check it with the diagnostics to see what part is bad but most likely it will be the touch pad.good luck with your dish washer.
Oct 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Drivers issues: Sound (Realtech) and Touch pad (Synaptics)
I would go to the Toshiba site and looking for the Synaptics and sound drivers and reinstalling just them.
Apparently something interrupted the updates and that affected the drivers.
Another thing you can do is start the computer with the system disk and choose the repair your computer option. It should check your hard drive for errors.
Nov 12, 2009 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 5315 Touch pad problem
go to the control panel, mouse configuration , and try to turn on the touch pad
Aug 30, 2009 | Acer Aspire 5315 Notebook
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
If it stopped working after you dropped it, try this:
Hold the Zen in your hand, and with your thumb, press down on the face board as hard as you can. Use your other hand's finger to scroll up or down on the touch pad. Press down different areas of the face board until you find a spot that, when pressed, causes the touch pad to work. Then, using both of your thumbs, press that spot VERY hard until the touch pad works without pressing.
Sep 29, 2008 | Creative Labs Zen Touch MP3 Player
No boot
Sounds like the motherboard is getting power to the lights but not to the rest of the computer. try to drain all the power out of the laptop by unplugging it and holding the power button for 30 seconds. Then plug it back in and try again if this does not fix it your motherboard is probably shot and would need replaced.
Jan 21, 2008 | Compaq Armada 1700 Notebook
Computers & Internet Logo
760 people viewed this question
David Payne
David Payne
