Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Connecting the wires
Disconnected the motherboard. finally found one to replace. but now which wire goes to what on the motherboard. Connecting it. Any picture or so?
  • BigFatGeek May 11, 2010
    When uninstalling the old motherboard did you leave all cables attached to your hard drives and CD/DVD/ Floppy drives? And have you reinstalled your processor on this new motherboard with thermal grease and heat sink yet?
    Problem Solver:
  • 12 Answers
>>>>User Manual Download<<<<
Here is the user manual of your MB. Look for ports and were to connect cables. The more hard are those little cables from the front panel chassis. Take a look and you would find the right combination. In computers everything goes one way just don't try to force anything. Let us Know....
Posted on Sep 18, 2008
Battery draining overnight,replaced with new battery now starting
Disconnect any one of the cable from battery (either + or - ) and in series with battery connect a 12v bulb of low wattage say 5w or 10w. By connecting in series I mean one wire of bulb goes to disconnected battery cable and the other wire to the terminal of battery from where you disconnected the cable.
Now observe the filament of bulb, if it glows then your battery is draining due to short in your vehicle electrical system. You need to locate this short circuit and fix it, otherwise your new battery would also drain.
Let us know what you found out.
May 05, 2014 | 1990 Ford F150
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
2 switch system. 2 black wires and 1 red wire in the switch. I have hooked up black wire from the switch to the red wire in the box. green wire from switch to black wire from the box and red wire from the...
You posted under ST01C and are wiring timer to replace 3-way switch.
Open following link for specific illustrations:
http://waterheatertimer.org/ST01C-program.html#ST01C
http://waterheatertimer.org/pdf/ST01C-explanation.rtf
1) The timer replaces one of the 3-way switches. The other 3-way switch remains, but must be rewired.
2) The timer must replace the 3-way switch that receives power from breaker box. It cannot replace the other 3-way switch. This is because the timer Black wire must always receive power.
3) The timer blue wire must connect to Load (light)
4) The ST01C red wire is only used when wiring for 3-way.
5) When the red wire and blue wire are connected together, they reverse the timer program. When timer red and blue are disconnected, the timer resumes programming. Connecting and disconnecting the red and blue wires is how the timer mimics 3-way operation.
6) The remaining 3-way switch must be wired so it will connect and disconnect the red and blue timer wires. So the remaining 3-way switch has to be rewired to meet specific timer wiring.
Jul 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Fuel guage on 1991 ford f-150 is pegged at full always
Ford and Chevy are opposite on how the fuel gauge reacts to shorted or open conditions and I can't remember which one goes which way, but at any rate, the problem is one or the other - either the wire is shorted to ground or the circuit is open. Check first at the fuel tank and see if the wire is connected. If so, try connecting a jumper wire from the metal of the tank to a good grounding point on the vehicle. If still nothing, check the condition of the wire all the way back through the circuit, looking for damage, pinch points, disconnections, etc. If there is nothing obvious, disconnect the gauge wire from the tank and see what the gauge does. If the gauge goes back to E when the wire is disconnected then the problem is most likely in the sending unit inside the tank. If the gauge remains pegged, try connecting the gauge wire to ground. If the gauge now goes to E it is either a bad sending unit or a bad ground connection at the tank. If there is no change when disconnecting the wire and subsequently grounding the wire then the problem is somewhere between the tank and the gauge along that wire and you just didn't find it during your previous inspection. Good luck!
Jun 30, 2011 | Ford F-150 Cars & Trucks
Reconnnecting wires from on my Gigabyte GA-7ZX motherboard
you can check the MB pinout diagram from their website. The powersupply connector generally of a unique size and you can easily identity by the pin numbers and safely connect it, as you cannot insert it in a wrong direction.
Nov 17, 2017 | Gigabyte GA-7ZX Motherboard
Power switch Wire has dissconected from the motherboard
There will be a series of pin headers on the edge of the board. They are almost always labelled PWR but if you haven't disconnected all the others (HD indicator, speaker, etc) it should be obvious where it fits.
Oct 03, 2009 | Computers & Internet
Liftgate ajar light on when liftgate is closed when driving interior light are on. I open and close liftgate, but no such luck liftgate ajar light on and all interior lights when driving
I recently had a similar problem with the "liftgate ajar" light lighting randomly on my 2001 PT Cruiser. It was even occurring AFTER I had disconnected the "ajar sensor" on the liftgate. Finally found that 5 wires were broken, one of them the liftgate ajar sensor wire, in the wire bundle that leaves the top of the liftgate and goes into the chassis. I suspect that those broken wires would randomly trigger. Inline spliced the wires and resealed the bundle. Everything looks good for now, although time will tell.
Jun 28, 2009 | 2002 Chrysler PT Cruiser
Dell Inspiron 710m laptop speakers no sound,
Chances are that the wires connecting the speakers to the main board have been cut. The same thing happened on my 710m, I no longer have any sound and have been trying to figure out how to get replacements, I've found a few on Google, but have some apprehension about opening up the whole thing and replacing them.
Hope yours is just a driver problem.
Dec 28, 2008 | Dell Inspiron 710m Notebook
Starter replacement on Volvo S90
There are usually 2 wires that connect to the starter. One is a large, thick wire, about the size of your little finger, It comes from the battery. The 2nd wire is a thinner wire, kind of like a soda straw. The large wire goes to the large terminal of the starter and the thinner wire goes on the smaller terminal. Be sure the ground terminal of the battery is disconnected before you try to hook up the starter.
Hope this helps Loringh PS please leave a ranking for me if appropriaye Thank you
Dec 02, 2008 | 1996 Volvo 960
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
