Question about Kicker KX1200.1 Car Audio Amplifier
Kicker kx800.4 sounds without power
I have a kx800.4 amplifier.
it was playing ok till one week ago.
the problem is that it plays but the volume is very weak, i have tried all the buttons and every thing but i cannot make to sound loud.it sounds but without power.it is the same in the 4 channels.i took it to workshop but they cannot figure out what going on with it.id like you to tell me what can be wrong with it so i can tell the repairman to fix it.
the repairman told he had checked everithing but hasn found anything wrong.
please help
    Problem Solver:
  • 12 Answers
Check to see if theres a gain port plug on the amp. It looks like a phone jack sometimes. If so make sure nothings in that port and make sure none of the prongs are touching one another. Thats the only thing i can think of the top of my head. It also could be a bad gain switch or something wrong with the radio and the line drop volts.
Posted on Oct 23, 2008
Why would my amplifier turn on but not send anything to my sub-woofer?
Try using a continuity tester turn the amp on as normal play the head unit and see if you get a reading or you can try using a different sub woofer if the problem persists I could be your amplifier then
Oct 07, 2016 | Kicker Car Audio & Video
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
I have a 300 Watt dual amplifier connected to one 12" kicker dvc sub at 2 ohms. Every time the volume is turned up the protect light turns on. I had 2 of these kickers wired to a Rockford amp a week...
Then you have found your problem. It's internal on the amp. Protection circuitry issue. Have it Benched at a shop with the same impedance you are running it at. If it benches ok, check your ground, it should be no longer than 18" and go directly to the floor frame, not a seat bolt. You should also be running at least
4ga power as well. Hope this helps.
Jan 11, 2011 | Dual 300W Class AB Bridgeable 2-Channel...
Sub not working
there might be transistors that went bad
May 01, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
Amp wont play sound when car is on but works fine when car is off
somehow you may be getting too much power but kickers love to **** power so i doubt it. it has to be getting too much power some how activating the saftey circuit cutting it off.
Apr 07, 2010 | Kicker IX702 Car Audio Amplifier
I have the JBL gto 601.1 apm its a 2 channel, i hook them up to 2 12 kickers, the amp will play the subs properly ONLY at low volume and the amp will spit and choke on high volume ( meaning that it will go...
ok first off bbbman78 is wrong!!! second off that amp is not a 2 channel amp!!!! i have the exact same set up as u do. an i was having the same issue. i discovered that the subs were not wired to the amp correct because the amp is a class D mono amp. and it does have 2 sets of terminals to wire subs to, but it is actually a 1 channel amp! ok if u have the 2 ohm dvc (dual voice coil) wire them like in this linkhttp://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_mono.jpg
if u have the 4 ohm dvc wire them like in this linkhttp://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_mono.jpg
once u wire them correctly.....crank it up and enjoy!!
Feb 28, 2010 | JBL GTO 601.1 Car Audio Amplifier
Heat at some transistors and resistors in suv800x
most likely you have played your with either spk bad or bad wiring i have the same exact amp played it hard for more than two year and still have it sitting right now just bench test it last week still drive hard i think you make bad connection some for that to burn like that
Jun 18, 2009 | MA Audio Hard Kore HK-898 Car Audio...
Power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
Nov 20, 2008 | Kenwood KAC-9103D Car Audio Amplifier
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
Kicker KX1200.1 Car Audio Amplifier Logo
61 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
