Cannot connect to internet on laptop 7201, had problems and restored to factory settings, aol say router operating fine
  • 35 Answers
You should firstly try to check the settings of internet connection according to your ISP (Internet Service Provider) also u should check your Physical connection if u r using Wired network then check LAN wire and also DSL connection.
Hope it will help U.
Posted on Sep 18, 2008
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
There is an orange "i"
The orange "i" means that the Ethernet cable connection to the modem has been detected.
The light should be blinking green for Internet connectivity.
I advise you to reset the router:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink .
If resetting the router does not correct the issue, you should call your ISP (Internet Provider) and check if they are having a problem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Router was working fine, then I upgraded the fw level to .29. When I did that, I could connect my 2 wireless laptop connections, but the 2 desktop pc's will not connect to the internet being wired. I have...
I hope you have a Belkin F5D8233 ver :3000 wireless router and you have upgraded the firmware version: 3.01.29.
It's a known issue with this model , only the wired connection will be not be online. Another information when you connect the computer in the 1st LAN slot you will have internet connection but not with other 3 LAN slot on the router. To fix this please follow these steps,
1. Log into the Belkin router setup page (http://192.168.2.1) in a wired computer .
2. In the left hand side under the heading Utilities? click on save/backup settings
3. When its asking for password to login leave it blank and click on submit.
4. Click on save to save the settings of the router in the Desktop
5. Then again under Utilities? click on restore factory defaults and then click restore defaults button, to restore the settings of your router to factory settings.
6. Then Under Utilities click on restore previous settings and select the file where you saved it and click on restore settings.
Then automatically you will be able to go online both wired and wireless.
I'm sure this would work. If it does work then please rank me and give me a testimonial
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | Computers & Internet
Have high speed internet, but don't have a modem, just a cable to my tower, I connect that cable to my router, and the cable the router came with I connect to my tower and won't get internet to my computer...
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Linksys Wireless-G Broadband Router
I just restored my laptop on factory defoult.Now I can't set up internet connection because I forgot pasword for my router Belkin54g. I have One desktop(main computer) and one more laptop in network
Assuming your Desktop PC still has connection, I suggest changing the password on that PC and then enter the new settings into the Laptop.
Hope this may help.
Mar 04, 2009 | Zhone (6218-I2-200) Router
Cannot get onto internet
disable the firewall on control panel.
check all the properties boxes on the network
connections and make sure firewall is disabled.
access the router setup and make sure that VCI is set to manual
and that you enter in the settings yourself (eg: 0,38 for aol broadband). Don't leave VCI, etc on auto, the router can't handle it.
Jan 09, 2009 | Buffalo Technology WHR-G54S Wireless...
Internet Connection from desktop
hey laure
you may need to go to control panel, then internet settings, then hit the connection tab, and make sure the 'never dial a connection' button is clicked. then apply and reboot if necessary. don't mess with the router settings and definitely don't restore factory settings, that'll blank out the ip address and other things.
you should be able to access the web, otherwise the ethernet cable fromj your pc to the router is plugged into the wrong port on the back of the router.
good luck
chris from scotland
01776840273
Dec 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Internet connection
the Ps3 should connect fine, if you have your wired router set up right to automatically assign ip addresses...(DHCP)..in otherwords, anyone who comes over with a computer from anywhere..even me..should be able to plug a lan cable in to your router and it should connect without changing any settings. If this is true, then you should be able to go into your settings menu, select wired connection type, hook up your lan cable...then select auto and east for the settings for ethernet. this should work, if any pc works. If not, you may have to call AOL for info on how to properly configure your router and PS3. The network issue is most likely a AOL issue, and not a PS3 issue.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
