Question about Garden
Will not run at fast speed
I have a craftsman 29cc 4 cycle gas trimmer and i can`t get it to a fast run, just a idle. What should i do?
  • Anonymous Mar 10, 2009
    The problem I have is, it starts up ok but as soon as I pull on the throttle it dies.
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    does it start to bog out like theres a heavy load or restriction on the motor or does it not react to the throttle at all?
  • 50 Answers
One possible problem is the cable clamp is loose, allowing it to slip. Check to see if the throttle is functioning.
Posted on Feb 09, 2009
Why when I pull the cord, the trimmer doesnot turn
Will not turn if it is clutch driven. When motor starts and revs are up it will turn provided the clutch is working correctly.
Aug 30, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
How do I adjust the float to get more gas. bring the float up higher or lower the the float?
Lowering the float allows the fuel to enter. As the float rises, the needle valve is depressed, cutting off the fuel.
Mar 09, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
How do you rebuild carberater on a 4 cycle 29cc weed trimmer
There is not much to it. There should be information stamped or printed on the side of the carb - maker and model#s. Take this information and do an internet search with it. You should find a rebuild kit for around $10. The kit should come with a diagram and directions. Take the carb apart, clean as necessary, reassemble with the new parts and you are good to go.
May 14, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
Weedwacker overheats
air leak around crankshaft, scrap it and buy a new Stihl.
May 23, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Cutting head on 29cc trimmer will not stop rotating at idle,cleaned filter,changed oil, cleaned spark arrester, tried adjusting idle speed, nothing seemed to help
You didn' t list the model number. Have you tried placing the head on the grass? does it stop then? It has a centrifugal clutch, if the idle speed is too fast, it will spin. There could be a broken spring or dirt in the clutch keeping it engaged.
Jul 26, 2010 | Craftsman Garden
What oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Garden Logo
488 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
