Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My pad, when I put in pass code #, will not open my garage door from the outside.
I thought the batteries were bad so I changed them out-no difference. Went to 'reprogram' my pad and it won't let me. I have my pass code # that we always punch in but I need my 'password' and both my husband and I cannot remember it. It's been a looooong time since we purchased our LiftMaster and we've not needed the password. Only the pass code # to get into the garage. I've looked everywhere for the manual or some place where we may have written down a 'password'. Can the pad be reprogramed or are we screwed??!! Thanks-
Help!! in Washington State
  • marty metzger May 11, 2010
    what brand and model of keypad?
    hoq ols is unit. Last 20 years you do not need password. get some model numbers and brand names.
  • 118 Answers
Simply reprogam keypad. Press and release learn button and the press the 4-digit code and press and hold enter until light flashes on motor,
Posted on Jun 16, 2010
2 Suggested Answers
SOURCE: My pad, when I put in pass code #, will not open my garage door from the outside.
We have a Craftsman 1/2 HP garage door opener with wireless keypad. Recently, the keypad has stopped working. I replaced the battery, but it still did not resolve the problem. I do not see a light and the keypad does not seem to be responding. Any ideas how I should troubleshoot this issue?
I have a do it best garage door opener,but the outside pad quit working.We put in a new battery.Got a new car and set it in the car to work,did this foul it up?
Hi Janice:
I have to ask the obvious question.
Is there any chance that the code got changed?
I'd try resetting the keypad code just in case.
Dec 08, 2015 | 2015 Ford Edge
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Changing code on keypad
i have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Jan 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
The key pad on the outside of not responding when put in code
If you have replaced the battery and everything else is working then the keypad has most likely quit. Replace it with one of the same model.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keeps opening automatically after code change
Changing the code on your keypad wouldn't cause this problem. It is most likely a bad wall control or the wiring going to it. You can eliminate both possibilities by removing the wire from terminal #1 on the rear of the motor unit. I would do that for a night or two just to see. You can then go further to eliminate the wiring or the wall control. If you replace the wire on terminal #1 and then remove the wires from the back of the wall control you will see if it is the wiring. The staples used during installation sometimes cuts through the insulation and cause this problem. The wall control just goes bad.
Sep 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
No power to key pad after new battery put in
correct polarity. what battery. 9 volt or a23, did you recode combo byu hitting learn button for a second and then entering combo.
Feb 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Outdoor keypad frequently doesnt work
IF REPLACING THE BATTERY DOESN'T DO IT YOU WILL NEED TO REPLACE THE KEYPAD.
NOTE: (IF YOU HAVE A ROLLING CODE SYSTEM) YOU WILL NEED TO REPROGRAM THE UNIT AFTER YOU CHANGE THE BATTERY.
HOPE THIS IS HELPFULL
Jan 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Battery does not last
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Aug 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
278 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
