LG Intellowasher wm1280fhd front loader, over flow (water does not stop)
Hi There
I have the above washing machine; when programmed it let water in and over fills. I have try to diognise the valves bi swapping the connections thinking that it may be valves but it does it on all of the valves. appart from the comput unit can it be something else. I hope any one can help it is a good machine though.
  • 1,031 Answers
  1. check flow valve washer faulty or wrong size if yes then replace valve
  2. water pressure too high then reduce flow of water by closing water faucets slightly
  3. water level control switch faulty check and repair hose connected to switch and take to a professional for testing if faulty replace
hope this helps if you still have further problem do let me know
Posted on Sep 18, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 19, 2008
    dont for get to rate this solution
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
May 14, 2010 | Washing Machines
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
