Question about Acer Aspire 5100 Notebook
Acer 5100 usb ports,Cam,PCMCIA
Started when my acer started acting funny so I formatted I made the restore disk right out of the box but some how this failed bad DVD bad operator who knows.? Pqservice partition is gone before i found out what it was I deleted it. So now I Installed Windows XP I Installed all drivers from Acer Web and usb,cam,and bought a card as a work around for usb ports but also does not work if you put a usb in it pops up unknown device. I have formatted and reinstalled more time than I wish to remember. Any Help?
  • urzica_alex Jan 19, 2009
    I have almost the same problem , I meen my USB ports are not working, when i plug in something it just says "USB Device Not Recognized" First I had vista, it was ok, I changed whit XP, it was ok... until it crashed.. (the XP) I tried to put back the XP but after "loading the necesary files" the setup did not started, I tried a couple of times but the same...just dead on starting windows setup, so I put back vista again it worked but my USBs ar dead...... What cam I do ???
This happened to me before - I have an Acer Aspire 5100. I had to take it to Acer (it was under warranty) and they changed the motherboard. Hope this helps =)
Posted on Sep 19, 2008
Aspire 5100 it does not recognise the keyboard
borrow a friends keyboard and mouse...log on to your computer and go to system restore and go back to a time when you knew you could use them and restore to that date
sometimes funny updates cause external hardwares to act up
Brentwood IT
Sep 25, 2009 | Acer (918EA10I10) Motherboard
Acer Aspire 5100-3357 lost function of keyboard, touchpad and USB
hello, this has been one of the most reported problem with the 5100 model. i have 2 of them, and they have done the same thing! one i had 2 find and install a new mainboard-400 bucks! not very cost friendly. i did post a solution more than a year ago, but it is a work around that let me use the acer with the dead keyboard,touchpad,usb- you must buy a pcmcia usb card, it goes in the slot on the left side of the acer 5100. then a usb mouse and keyboard will work. (you can get this cardbus adapter cheap, as 400 bucks is 2 much. these pcmcia cardbus card come with 2 or 4 ports. this will let you use the pc, it has been a great solution for me and a lot of others, been in use over a year like this. acer is no help, unless you wish 2 spend a large amount of $. the one with the new board lasted about 8 months before the usb port stopped working for the second time, i then got a second cardbus usb card and have usb again. sorry for your problem.. good luck! do as i say and the acer will work again.( a problem model) just search for pcmcia usb cardbus you will find many 2 choose from- i picked the ones with the NEC chipset, as these are reliable! be well!
Sep 21, 2009 | Acer Aspire 5100-3357 Notebook
Acer Aspire 5100 ; mouse freezes right after boot up
hi, yes it is a motherboard issue-i have 2 of those with same problem. new boards for that model are costly. however i found a work around-get a usb pcmcia card put it in the slot on the side-then plug your mouse or other usb devices and you should be ok! I did this a year ago and it runs like new! way cheaper than getting a new one. this is a big problem with these 5100 models. acer no help-other than selling you a new mainboard. this is the best way 2 make it work again. the pcmcia cards are cheap enough. and after that you can get a usb hub if you need more ports. good luck! and please rate this solution. and make sure 2 turn on the cardbus if not on allready. (in epower manager) this will work! reply if you need help! be well!
Jun 07, 2009 | Acer Aspire 5100 Notebook
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process.
Jan 17, 2009 | Acer Aspire 5100 Notebook
All USB ports not working
Sounds like a shorted out board. If you use a faulty device.. these can EASILY short out the USB controllers on the motherboard.
Alternative is to purchase a "PCMCIA USB expansion card" till you can replace the motherboard.
best wishes.
Oct 30, 2008 | Acer Aspire 5100 Notebook
My acer aspire 5100 as put me into trouble
i had the same problem. apart from keyboard and mousepad, all usb weren't working at all... except the pcmcia slot. so i bought a pcmcia usb card and plugged in the usb mouse and keyboard in those slots. it works! at least on my aspire 5100
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Acer 5100 laptop USB ports freezing touch pad
Maybe your thumbdrive is the problem try to format the thumbdrive first
Jan 22, 2008 | Computers & Internet
Keyboard and touchpad locked up
Sounds like its faulty :(
Easy fix is to use a usb mouse and keyboard but not the perfect solution i understand.
Jan 06, 2008 | Acer Aspire 5100-5033 Notebook
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
226 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
