Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover Upright...OLD vacuum, broken belt
I can't figure out how to get the wooden rod off that the belt goes around..
help! I have the old belt off and the "cover" removed. This vacuum is ancient (over 15 years old at least) but runs good with a belt that is not broken!
Barb
    President:
  • 1,673 Answers
The rod must be your brush roll. it should just pull out, Have you removed the cover over the brush roll? When you do get the brush roll out, turnb the ends and make sure they turn freely, if nit, replace it also.
Posted on Sep 18, 2008
Hoover Elite 300 belt replacement?
Take the broken belt to a vacuum cleaner repair shop to match it up to a replacement.
May 27, 2013 | Vacuums
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
Belt will not stay on
Those machines have the belts on them at production.
You can read about this
www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Change the belt! Good as New!
Good Luck
The Vac Dr.
Dec 21, 2012 | Hoover Elite Rewind Bagless Upright Vacuum...
My brushes won't spin on my Hoover Steamvac F6020900. Any suggestions?
There is a rubber belt that goes around one side of the brush to make it spin,It sounds that the belt is off or broken. Replace the belt.
Jan 25, 2010 | Hoover F6020-900 SteamVac Upright Vacuum
How to replace fan impeller on old Hoover upright. Taking off the belt pulley is giving me the problem.
Depends on how old it is ... if it is real old try putting a open end wrench on metal belt pully, and then hit wrench with a hammer i think counter clockwise to loosen
Mar 26, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Aug 10, 2008 | Hoover Vacuums
Houver Cleaner
Take off the bottom plate, The flat belt ges around the motor shaft and then around the bigger pulley by the V belt. It will stretch to o on.
May 15, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot get new belt on
no need to remove motor shaft which is integral with motor. slip belt on motor shaft first, then on roller then pull roller back to correct position. needs a little force
Jun 06, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
61 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
