Question about Gateway Computers & Internet
Have an old Gateway G6-400 from around 1998. It's had few and minor problems over the years, and has been used at least normally if not heavily throughout the period. The other day it was acting up a bit, so I decided to just shut the power down completely for a while. After a couple hours, I went to turn it on and NOTHING. So, I unplugged the power cord and let it sit for some more time. Next day, I plug it in again (now, bear in mind I've alreaady taken the thing apart, looked at everything including the power button itself, used multimeter to check cables, etc. I've already tried just about everything without taking the WHOLE thing apart) and it starts. But not for long. It gets to about boot screen (W2000) then power just cuts. If I then try again, NOTHING. However, I unplugged the power cable yet again, waited some time, and it started with the same result. I even tried to get to the BIOS screen to see if there was anything there, and to try and change boot options right quick to boot floppy or CD so I'd MAYBE have a chance to hack something out before power just GOES again. Didn't work. So, today I can start it up again, but it only stays on a little longer than before. This makes me suspect a capacitor at fault, though it's been years since I did any serious electronic work. I do remember that they can blow or "go bad" to the point where they still work, only in a limited "capacity" (pun intended, I crack me up!). Anyway, I just wanted to find out if there are others who have suffered this same kind of situation. This was my home network and Internet server with two NICs and literally thousands and thousands of personal files that I can't recover without moving HD's around or something. ANYONE?
I suspect it is the power supply. If you've had it up and running constantly, the power and/or temperature cycling could have been enough to put it over the edge if it was close to failure anyway.
Posted on Oct 19, 2008
If I find a solution to this, you want ME to tell you how I did it? Do I get paid? Or I guess you just post it for your paid "members", and you get it for free, that's how I figure it works. Yeah, I'll tell you how I fixed it, for the price of a stupid "membership". These kinds of things SHOULD be shared, but only if EVERYBODY can access it. Dream on...
Posted on Sep 30, 2008
Why does the belt on a riccar vacuum keeps coming off?
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
Feb 04, 2017 | Riccar Vacuums
Rumbling at 40-45 mph, minor oil and coolant leakage
Get a oil change our put liquid our bleach were you put the liquid for the oil change
Mar 05, 2014 | BMW 325xi Cars & Trucks
How to ck drivers window motor it did work then stoped
Get yourself a new regulator on ebay or at a parts store and pay an auto glass shop to install it for you. Way cheaper than a dealer and the regulator being over 10 years old, and the heavily used driver window, it should be replaced.
Oct 12, 2010 | 1998 Buick Century
I have a 6 year old gateway desktop, it has windows vista. The computer will not stay turned on when i boot up (won't boot up), i also use it as my wireless master and do not have any issues with my...
This might be a heating issue. Considering its 6 years old pop open the case and use dust off and spray it down until there isnt any dust left near, in or around the heat sink. try that and if it doesn't work try re-seating the heat sink on the possessor and clean off all the thermal paste and re apply some new thermal paste.
Oct 25, 2009 | Gateway Computers & Internet
Anti theft wont release start up
I had the same problem on my 1998 Dodge Caravan LE with 3.8L. I did some research, tried different things but what fixed the problem was removing the instrument cluster and resoldering the 4 pins on the back. In 1998 they changed from using lead based solder to a non lead formula, this new formula tended to give cold solder joints, that is joints with poor electrical connection. The instrument cluster is fairly easy to remove, the main problems I had were with the emergency brake cable that has to be disconceted from the release handle and also the light switch panel posed a minor problem. A few screws and an electrical connector and the instrument panel will come out. Use a solder suction tool to remove all the old non lead solder and then resolder with a good lead based electronic solder. You won't need a lot of solder and it is best not to have any excess on the connections. A good connection is when the solder flows smooth around the pin and on the circuit board. I did this on my 1998 Caravan 2 years ago and I haven't had a problem since. Good luck, hope all goes well.
Aug 07, 2009 | 1998 Dodge Caravan
Gateway FPD 1730 Monitor
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
Jul 10, 2009 | Gateway FPD1775W Monitor
REFRIGERATOR NOT WORKING BUT FREEZER IS
The ice could be related to a defrost problem. Check the back wall of the freezer for ice buildup. The evaporator coils are behind it and if iced heavily will block the circulation of cold air.
Jul 01, 2009 | Refrigerators
The wrong power cord was attached and now it wont do anything i think its burned out
Most likely it's just a power regulating diode on motherboard right next to DC connector, that burned out. Minor repair, but expansive.
Apr 18, 2009 | Gateway MT3705 Notebook
Computers & Internet Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
