Question about Refrigerators
Kenmore refrigerator compressor relay and overload switch wiring diagram
  • 3 more comments
  • Anonymous Dec 07, 2008
    In the morning this @# Refrigerator, a Kenmore side/side w/ ice, water, just stopped getting cold, yet cool air was blowing inside the housing (?), yet the rest of the system was noticeably working. I raised the temperature dials, and the system began to click repeatedly (loudly). So, I removed the back paneling and noticed some electrical arching right where the compressor/ relay are housed. I have a strong feeling that the relay/ overload switches went bad/ out; hence the compressor cannot be activated (?). So, my question here is: how do you remove the relay cover. Keep in mind that I have followed the inscription on the plastic housing cover, yet, to no avail. Can I simply, yet safely, rip off the cover’ or, do I have to revert to some-how pulling out the compressor to get better leverage in working on it. Once there is room and I can pull out the relay/ oL~ I know once out your to smell for burn and/or shake the relay/oL components to hear if rattling is present; rattling being equaling bad for a relay So, if possible for you to come up with a plan to remove, check and preferably, help me purchase the correct relay/oL switch. ee
  • esanto2
    esanto2 Dec 07, 2008
  • porschmn Dec 09, 2008
    I have the same problem with my frig. You pull the silver band off and you'll gain access to the relay. When I went to the parts store the ordered a part number 664982. My relay has two connector blades to slide on a pair of double wire connector on to. This piece in turn is plugged onto two prongs coming out from the compressor. The new part has one connector blade with two small blades one with a copper wire and one with a silver wire welded on. The best of all there are no damn instructions. So if some idiot tells you to simply order part number 664982 and doesn't tell you how to connect it kick them you know where. Porschmn
  • rican51 Mar 31, 2009
    my fridge compressor relay burned and melted some of the relay metal to the tip of one of the prongs on the compressor. could i try to apply heat and melted off the prong so i could plug a new relay? a tech said that it wont work and that i need to replace the whole compressor.
    thanks for any help.
  • Anonymous Apr 05, 2009
    How much is a compressor replacement for side by side
    e
    Scholar:
  • 44 Answers
The method of starting the compressor on very old units was that a real relay would close its contacts for a few seconds shorting the connection of the start(S) post on the compressor with the run(R) post thus feeding power to the start coil in the compressor for a few seconds. Well, I guess the bright design boys/girls were told to design for less cost and eliminated the real relay altogether. In its place they made a little plastic holder that has a disc type thermistor inside it. Normal resistors have a negative temperature coeficient meaning that as temperature goes up the resistance goes down. Thermistors do the opposite so as temperature goes up the resistance also goes up. They stuck one of these little thermistor discs about the size of a penny and just about as thick between the S and R terminal posts on the compressor so that when the thermostat in the refrigerator calls for more cooling power goes to the R post and through the thermistor disc to the S (start coil) post thus energizing the start coil in the compressor and giving it the jolt it needs to get going. Since the thermistor is left connected across there it heats up from the current going through it. I measured the cold resistance of one disc at exactly 5 ohms. Using ohms law of voltage squared divided by resistance gives us for a 120 vac circuit quite a bit of power: 120 X 120/5 or around 2880 watts that might be needed to be dissipated by that little disc thermistor every time the compressor kicks on. Of course the thermistor gets really hot and its resistance goes up thus limiting the current and everyone is happy...for a while...years if you are lucky. Back in the 1960's I worked at Western Electric Co.'s Lees Summit, MO plant and was responsible for lines making thermistors including the disc type...they do a great job for the telephone company where not much current goes through them...but for high current applications such as controlling starting of refrigerator compressors the "black cookie dough" they are made of gets real hot...I mean really hot...and the dough dries out even more and finally breaks down often shorting out and leaving a black carbon mess all over everything plus the heat can cause a fire...so the old design was better as far as I am concerned using relays that often lasted 40 years with no maintenance. I digress...again... I just repaired yesterday a Kenmore side by side that was thrown away on the street...with melted run terminal post on the compressor from the blown up thermistor and it was thought by them and the service guy that the compressor was bad as well. An ohmmeter check showed indeed that all the compressor terminals were shorted to each other and to the compressor case ground. I then unbolted the compressor and gently bent the freon containing copper tubing allowing me to pull the compressor out to give good access to the terminals. I wire brushed the three terminals and around them on the compressor real good and cleaned it up using carburetor spray cleaner, allowed it to dry completely and retested with my meter and...behold...no more terminal shorts to anything and the resistance measured of the coils inside the compressor were good readings.... so... I then made a test cable which would plug into a 120 vac outlet. I then connected the 120 vac between the common(C) and run(R) compressor terminal posts while simultaneously using another wire through a push button switch to feed power also to the start (S) terminal for perhaps 2 seconds...alla kerzam...the compressor started and ran fine. I left it running for a while and found that a cup of water froze in the freezer compartment in about 1 hour. Then I installed a new thermistor unit and jerry rigged a way to make connection to the melted stub on the run(R) terminal, put the whole compressor etc. back in the unit, put the cardboard cover on and it has now been doing an excellent job of cooling ever since. You may not want to go to all this trouble...but..hey...I got a 2 year old side by side kenmore that the people said they paid over $1000 for and I only spent $22.88 on it on internet for a new start thermistor/overload module...even so, I would have preferred to use a start relay.
Posted on Aug 21, 2009
My side by fridge isn't getting cold. The freezer defrosted on me and my other side of the fridge isn't getting cold. but its still running would this be my compressor
Posted on Dec 16, 2008
My refigerator has a loud sound that has vibration and it seems like the compressor is moving and jumping up and down like its loosened off its mounts. the frig is still cold but the unit itself is bouncing up and down make terrible sounds. Help
Posted on Sep 22, 2008
    Problem Solver:
  • 9 Answers
If the compressor is noisy and bouncing when starting, the compressor mount inside the hermetic dome is broken. You would need to replace te compressor to resolve the problem.
Posted on Jul 21, 2010
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: kenmore refrigatorstart/relay/overload switch has burned spot on
HI. i would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each model). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
Posted on Jan 10, 2010
The start relay on Kenmore model 596.58642890 replacement question
The original relay switch has 3 terminal contacts on the compressor side. On the wiring side it has 4 contacts... 2 are start capacitor connections and two at the bottom of the relay are the A/C 110-125 volt line in connections. The replacement part you bought is a genericreplacement for the ref. The correct substitute part is W10189190 . The two wires for the original relay in the top horizonal position evenly spaced apart... ignore the 2 wires. They are wires to the old start capacitor mounted somewhere near the compressor. The other two wires are important to configure them properly. One may be blue and the other red. Here is a cheap way to know which is the right configuration... Use a volt ohmmeter and check the continuity from the refrigerator ground terminal on the A/C line cord or chassis to both A/C line in wire connections to the relay. If the ohms are zero or very near to zero then that is the ground/ aka neutral wire. The neutral wire connects to the bi-metal overload protector built into the relay. That is the bottom center connection terminal on the compressor. The other A/C line in wire is the hot wire and it connects to the Start/ Run connection on the new relay. http://www.appliancezone.com/ShowProduct.aspx?ID=28271
OR
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/10097202/0046/596/Model-59658642890/0582/0165000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P8090243&diagramPageId=00010&productTypeId=&searchModelNumber=59658642890&subCompDesc=Machine%20compartment/muffler&brandDesc=KENMORE&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&blt=11&shdMod=59658642890&keyId=251
Feb 07, 2014 | Kenmore Refrigerators
Side by side Kenmore Elite, Mod. 52794100. both sides have stopped coolding/freezing. There is a click, buss, click. Cleaned coils 6 weeks ago. Someone suggested it could be the starter switch?
Is that buzzing/click you hear from the compressor area?
If it is from their, the relay on the compressor has gone out, OR the compressor is locked up.To determine which of those it is the amprage draw using a amp meter clamped to the wire on the overload thermostat where the relay is, must be measured, if 17 or higher amps the compressor has locked up, if its around 5 or so the relay has gone out and replacing both relay and overload will fix it.If the compressor has locked that is a major repair and may cost up to $1200
Gene
Aug 23, 2011 | Kenmore Refrigerators
My Kenmore 106.56573300 is not getting cold and is clicking.
sounds to me based on your description that you possibly have a bad relay on compressor. it is possible the compressor has failed due to a bad start relay and what you are hearing is the overload kicking out when trying to start.. you will have to remove the back cover from refrigerator and gain access once you gain access remove bottom cover and you will see compressor... you can get parts from several online appliance places... kenmore i would probley go to
www.sears.com then hit the parts direct link on the top of page
enter your model number and a parts diagram will appear go to compressor picture and pick the relay /start and overload give that a shot if it still clicks the compressor has failed and will need to be replaced // good luck to you
Jan 22, 2011 | Kenmore 53642 / 53644 Side by Side...
Free Refer Hotpoint csx27dma. Owner had two new parts for the compressor. a start switch and an overload switch. The compressor has 3 round connection prongs for these parts to fit on to. Installed...
From cabinet you have three wires. 2 Orange,and 1, Black
1 Orange goes to on side of run capacitor the other Orange goes to the (2) R on the relay. The Black goes to the overload (round black disk). 1 White wire connector on end goes to run capacitor the other end connects to the (1) S on the relay.
The run capacitor is a small black cube like device with two prongs.
Oct 26, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Wiring diagram for 8201555 compressor installation
You should not need a wiring diagram for the compressor. You have overload relays and most only need 2 wires. Line and common. If you have an orange wire then that will be a neutral also.
Mar 02, 2010 | Kenmore 57029 Side by Side Refrigerator
Compressor relay & overload kit bad On a 1979 Kenmore Refrigerator
90% of the time the oL is doing its job by switching on and off. If it starts to burn or go open circuit, its because the compressor is tight. Bottom line compressor needs replacement.
Sep 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore model 596.52673202 refrigerator not cooling or freezing
the defrost should be controlled by a timer every 10 hrs or so,it is usually in the bottom of the fridge by the compressor,it has a small motor that turns the timer,they burn out
Jul 21, 2009 | Kenmore 53642 / 53644 Side by Side...
Starter overload switch
Relay is bad just replace it it is a safety to keep the compressor ok in the event of power surges or failures
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Compressor not running
This is the overload/relay assembly. Although a burned up overload can sometimes indicated a defective compressor, in most cases you can fix the problem by replaceing the overload/relay.
Oct 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
12,010 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
