Question about Microsoft Xbox 360 Console
Xbox 360 hard drive
Hello Sir,
My hard drive to my 360, starts to put in my name. However it cuts my connection off. Then it starts over again an again !!
HELP !!
  • 31 Answers
You have a networking problem or your cable is bad check all your cables if your cables may look good but if a pinched wire has occured you will get a cut off connection like that if not you will have to redo all of your networking settings if you call 1-800-4myxbox they can help you have your gamer tag ready and your serial number from the back of your xbox or in front at the usb ports
Posted on Sep 18, 2008
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
Jul 18, 2011 | Microsoft Xbox 360 Console
Have just added a hard drive to my son's xbox360 but it isn't recognising it. what should i do?
sir i think the way how you added a hard drive on your xbox 360 is not correctly... try this instruction on how to add a hard drive on your xbox360...
The Xbox comes in two versions, one with a hard drive and one without. Enhance game play and speed by adding a hard drive to cache the game data during play. Adding a hard drive or swapping out the original for a larger drive is easy and gives you as much storage as you could ever want.
Difficulty:Moderately Easy Instructions
    • 1 Select a hard drive with enough space to hold all of the games and media you wish to carry with you. Look for drives with 7200-RPM specifications for faster speed when loading and caching games.
    • 2 Format the hard drive to FAT64 using the Windows format utility. Drives larger than 32 gigs will require third party formatting software although Windows 98 is capable of formatting up to 127 gig drives.
    • 3 Turn off the power and remove all cables, including the audio, video and controller cables. Lay the Xbox on its side with the front facing you. Look at the left side and pull the hard drive cover away from the console gently.
    • 4 Place the hard drive over the Xbox hard drive bay with the tapered end towards the front of the console and the connector end toward the bottom. Connect the cable carefully and verify no pins have bent.
    • 5 Align the hard drive slot with the back of the drive and set it into place until you hear a click. Press the cover on carefully and connect all of the cables. Turn the power on and verify the Xbox powers up properly.
Read more: How to Install an Xbox 360 Hard Drive ' eHow.com http://www.ehow.com/how_4392665_install-xbox-360-hard-drive.html#ixzz1OyZkTiai
if you think this help you please rate me sir thank so much...
Jun 11, 2011 | Microsoft Xbox 360 Console
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
My xbox doesnt start the power light turns red
Hello Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shad0w
Aug 20, 2010 | Microsoft Xbox 360 Console
When i switch on my xbox 360 error code 68 appears and one red light on the system
Hello Sir =)
E68:
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
Aug 16, 2010 | Microsoft 20GB Hard Drive for Xbox 360
The xbox has a error code 69 and I cant seem to fix it. So if you know what the problem is please help me out and its on the forth person spot
Hello sir
It's Code E69
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Apr 08, 2010 | Microsoft Xbox 360 Console
One red light
Hello Sir
Fix-shad0w
Oct 08, 2009 | Microsoft Premium System for Xbox 360
Flash drive for 360 Xbox
Hello my name is Tim Ehrhart, You can download games to play off marketplace but they are downloaded to your hard drive and system and can not be transfered to a flash drive.
Mar 18, 2009 | Microsoft Xbox 360 Console
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
I got a new xbox
take the hard drive off of the old xbox and put it on the new one and get a memory unit and put all the game saves on the memory unit put the new hdd on and transfer the saved games from the memory unit on to the new hard drive and there you go.
Sep 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
