Question about Philips DVP620VR DVD Player/VCR
Philips DVP620VR no picture on VCR
Will playback (and record) sound on VCR but no picture (only "snow"). Was working fine till the other day. DVD still OK. Any ideas? Thanks.
SOURCE: no sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Posted on Jan 16, 2008
SOURCE: magnavox mwd2205 - VCR Function
what is the three code for recording a tv program on dish network
Posted on Apr 17, 2008
  • 63 Answers
SOURCE: vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Posted on Jun 26, 2008
SOURCE: Philips DVD Recorder
I may be a bit late but I just upgraded my firmware. I downloaded the zip file and burned it as per the instructions with Nero Burning Rom. This may help. Visit the Philips website and search for your Dvd recorder there.
Posted on Jul 10, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Philips MRV700VR DVD Recorder / VCR Combo
Crack the top open and look inside for any foreign matter. Usually the cause is debris in the IR path that detects start and end of tape or the loading mechanisim is faulty.
Posted on Sep 24, 2008
Is there something wrong with my cable setup?
i have had a few of those,it is not worth fixing
Jul 09, 2015 | Philips DVP620VR DVD Player/VCR
How do i record a vhs to dvd?
Unfortunately you are not able to record a VHS to DVD on this player.
It does not have the capability to record DVDs, in order to do that, you will need a DVDr
(DVD Recorder)
Hope you found this helpful.
Mar 17, 2011 | Philips DVP620VR DVD Player/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
We have a vcr/dvd, model dvp620vr/07, we are having probs recording our pics onto a dvd and having the recorder play it, our computer will, why not the vcr/dvd recorder, what kind of disc do we need to...
What program or software are you using to make the DVD? The DVD must be "finalized" before it can be read on an external device, such as a VCR/DVD player. PC's however, can handle the un-finalized (is that a word?) discs because it assumes you may want to add more files (pictures). Once the disc is finalized, no more files can be added to it.
Dec 31, 2009 | Philips Phillips 16X External DVD 2XRW...
How can i change sattings NTSCto PAL in my Philips DVP620VR DVD
Check this link to find the manual for your DVD player:
http://www.retrevo.com/support/Philips-DVP620VR-DVD-Players-manual/id/446ag723/t/2/
May 06, 2009 | Philips DVP620VR DVD Player/VCR
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Vcr
sound slike bad head on vcr side samsung makes new dvd vcr in one thats nice 79 on sale at circit city ok
Oct 06, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr only plays in black and white
Hi Ryana,
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
Philips DVP620VR DVD Player/VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
