Question about Candy Washing Machines
CTD 105 -appears to select spin cycle which ever cycle is selected
SOURCE: washing machine fault
what does the rror code h6 mean on a daewoo washing machine
Posted on Jan 07, 2008
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
  • 1218 Answers
SOURCE: Washer will not spin, on rinse or spin cycle.
Good day,
Almost always the lid switch.
Here is a good tutorial on replacing it. It should be noted there are 3 different lid switches depending on your model, and as well, the screws that hold the top console may be in 3 different locations.
Bottom left and right, bottom left and right but under plastic end caps that have to be unclipped and finally on the bottom but at the rear.
Kenmore's are built by Whirlpool.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on May 12, 2010
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
My washing machine goes through the wash cycle but when it comes to the spin cycle nf appears and it will not spin. I have to manually shut off and then press the spin cycle to complete the cycle, why is...
If this is happening with all the spin cycle then the program controller has some errors.
It will be good to select all the different programs to confirm on the fault.
Tighten all the connections, the leads to the controller.
Oct 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How much bleach do you add during cleaning cycle?
If the model number is correct, to run a "Clean" cycle on this model washer you need to follow these steps:
1. Make sure wash tub is empty and close the door.
2. Open the dispenser drawer and remove the plastic divider in the MAIN DETERGENT compartment.
3. Select the following options:
a. Select the POWER button.
b. Select RINSE/SPIN.
c. Select LOW SPEED SPIN.
d. Select WARM/COLD water temperature.
e. Select END OF CYCLE SIGNAL to SOFTER.
f. Press EXTRA RINSE button 4 times within 5 seconds and the
will begin.
4. The washer will run a short sensing cycle for about 3 minutes.
5. The washer will beep 4 times and a code will appear on the front panel display.
a. If "Ab" (Add Bleach) appears - skip to step 6.
b. If "Rl" (Remove Load) appears - the door will unlock and you
need to double check the wash tub for any items. Close the
door when complete and press the START button.
6. Add bleach. If this is the first time running the clean cycle add ONE CUP of bleach to the detergent compartment of the dispenser drawer. If this is a monthly routine, add only 1/3 CUP of bleach.
These instructions are listed on page 18 of your owner's manual. If you no longer have a manual, yo can obtain a FREE copy at managemylife.com. Just type in your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format that you can download or print for free.
If you have questions, please post back and let me know. I hope this helps you.
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My ARF 105 will not spin
Now if the machine is still full of water I need you to bail out some of the water by hand with a pot or bucket.Bail out just enough so you can look under the machine to the front right.You should see a pump with a red or black fan attached to it.If you see this pump try turning the fan clockwise and anticlockwise a few times to loosen it just in case it is jammed.Then put it back on its feet and select a spin cycle and push start.Hopefully it starts to drain.Please reply to tell me how you got on or if you have the pump with no fan attached.
Jul 24, 2010 | Washing Machines
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
