Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Vertical lines My Hannispree monitor has always worked incredibly well. All of the sudden two days ago, vertical lines started taking over the screen. Starts of as a distraction and then after ten minutes or so the vertical lines completely cover the screen so the information is nearly invisible. Help!
    Scholar:
  • 45 Answers
The monitor sounds like its going to die. The problem is because of the LCD Panel.
A monitor should have 2-3 boards, a logic board, an inverter, and a power supply
Lastly the LCD Panel which should consist of a crystal mirror, LCD Panel(has the circuitry and the brains for information/images that display), and backlights.
The LCD Panel is the problem. It needs to be replaced.
Yes it sucks, but usually LCD monitors last for so long, but in some cases they wear out by use and the thin circuitry that provides the power to create colors and images, begin to die. Im sorry. Its really the only solution unless you have the expensive equipment used to make the panels.
My recommendation is to replace it and it should work spankingly new.
I wish yuo luck. Please Rate.
Posted on Sep 18, 2008
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
How can I remove the thin vertical bluish line on the left side of my laptop monitor? My pc is Aspire 4738ZG and just bought this 4mos. ago. The vertical line just appears suddenly on my laptop screen and...
If this line is present on every window you open, it may be a problem with the LCD itself. As it is new and I presume still under warranty, I recommend you to take it back to the after sales to get it checked.
By experience, I can tell that in most cases, this type of line on the monitor comes from a defective LCD monitor, and if it is the case, it should deteriorate with time.
May 10, 2011 | Acer Computers & Internet
Dell E207WFP monitor
.Bad news.It cant be fixed.Try to take it back to the shop and get a replacement one.It might work for a few months or so but it is certainly a faulty screen.
Jul 21, 2009 | Dell D1028L 17" CRT Monitor
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
230 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
