Question about BenQ Projector Lamp for PB8263
Alfonso My projector turn on but in 1 minutes turn off, it display lamp error but the lamp is new, please help me
  • Anonymous Apr 02, 2009
    same thing, new bulb, the projector still thinks its bad, is there a reset button?
How do i reset my lamp after replacement?????
Posted on Sep 22, 2008
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
I HAVE ONE VP6321 DIGITAL PROJECTOR , P/N L1793A. In that when we switch ON display will come after 1-2 minutes one sound will come and display goes off. Can you help me to find what will be problem.
It sounds like either the filters are blocked or the lamp needs replacing.
The filters clean the air that the projector sucks in to cool the lamp. If the lamp gets too warm it will shut down to protect itself.
Clean the filters first and if that doesn't work, you may have to purchase a new lamp.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard vp6321 DLP...
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
Turn on the roadrunner L6 the preparation display
This is an indication that either the lamp is bad or the ballast is bad. I would try a new lamp first. Also, there are air flow sensors in the lamp area that should be cleaned. If you have access to compresed nitrogen, try blowing out the entire unit to remove all dust and debris. Check to be sure that the fans are turning freely as well.
Please keep us posted.
Dan
Mar 03, 2010 | Christie RoadRunner L6 Multimedia...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Mar 05, 2008 | Sharp (BQCPGC20X1) Projector Lamp for...
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
BenQ  Projector Lamp for PB8263 Logo
304 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
