The left arrow button on my nintendo ds lite wont work. the only way to get it to work is to press really ******* it. is there a way to fix it so it will work again?
onj this search there are two fixes one involves the spring being replaced and the other replaces the button itself i suggest you replace the spring fisrt because it involves no soldering if that dont work go for the button but requires soldering skills
try the calibration in the options. try tapping or if not working, use your buttons. tap or use the button to make the origin at the center of the screen.
hey guys!! i already fixed this problem by using the technique to fix ur R button. it is on utube. it can fix any of ur buttons as far as i am aware. it worked for me!
This is really hard to realize because you need to leave it to a supporter unless you r one you can fix it. Its a hard process for noobs on fixing things.
From looking around, you can get replacenet parts for the DS. Its a little tricky though. Do you have any friends that mess around with building and moding computers? They may be able tohelp you
The thing that cross731 said really really helps. If your too scared to open your ds/ds lite, just put your nail under the trigger pull up and just blow into the little hole that you see. It works I just tried it and my left rigger is working just fine.
