Question about Golden Technologies Companion II Travel Scooter
Scooter stalls driving over sliding door tracks; scooter dies
  • Anonymous Dec 04, 2008
    My ignition (where key goes in) is wobbly and won't tighten, so any bump knocks out the power. Until I can get it repaired, I have to bungee cord the key tightly in the hole so it won't stall as much. I have a Fortress 1704 4-wheeled scooter.
  • Dan Hudson May 11, 2010
    What type of battery packs do you have, the type the plug in, or the ones that just touch a contact on base of the scooter?
  • Golden Techn... Master
  • 1,263 Answers
Hi, the wiring must loose around the key switch, it might be a case of taking the tiller off and resoldering the wires onto the key switch. It not a major repair , just a case of getting the tiller panel apart and locating the wires to the switch.
Regards
GeWiz.
Posted on Dec 25, 2009
  • 32 Answers
If this is a companion-II scooter, it may be the main wiring harness which runs for the rear to the front of the scooter. Make sure the connection is good by opening the rear compartment and checking all connections.
Posted on Jul 12, 2009
What causes engine to ABRUPTLY shut off while driving ?
2004 Ford Explorer Engine Stalls/Cuts Out While Driving: 31 ...
www.carcomplaints.com/Ford/Explorer/.../engine/engine_stalls_cuts_out...
... 2013 · 2012 · 2011 · 2010 · 2009 · 2008 · 2007 · 2006 · 2005 · 2003 · 2002 · 2001 · 2000 ... 2004 Ford Explorer engine problems: engine stalls/cuts out while driving ...to overheat and slide out of its socket, causing the engine to shut off. ..... Suddenlyat 30-35mph, my engine just died and i cannot control the steering wheel.
2005 Ford Escape Engine Shutdown While Driving: 24 ...
www.carcomplaints.com/Ford/.../engine/engine_shutdown_while_drivin...
The 2005 Ford Escape has 24 complaints for engine shutdown while driving. ...January 22: Ford Ranger Driver Killed by Takata Airbag in South Carolina news ' 2 days ago; Ford Focus Door Latch ..... I was 80 miles from home when the engine shut off. .... No one could seem to determine the true cause of the problems.
Ford Ranger Stalling/Dying Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Ranger
Nov 2, 2007 - 31 posts - ‎21 authors
Learn more about Ford Ranger at the Edmunds.com Car Forums! ... cut off a couple of times then it started happening more frequent while driving. ..... the other day I was driving down the highway and it just shut off, no warning .... 2000. when it gets overheated the circuit shorts and causes the engine to die. Ford Expedition engine cutting off while driving
Oct 24, 2009
Mercury Mountaineer Start Stall Idle Problems
Oct 1, 2007
More results from forums.edmunds.com
Jan 27, 2016 | 2003 Ford Ranger Regular Cab
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
How to remove the sliding door
Push up on the sliding cabinet door to release the bottom of the door from the track. Pull the door out and away from the bottom track and pull it down to remove it from the cabinet.-----------------------------------------------------------------------------
Renault CAN Clip Diagnostic Interface
Dec 05, 2012 | 2002 Mazda MPV
My scooter starts runs good then dies
Replace the battery, after sometime the battery starts to lose it's initial capacity.
For battery replacement go to Goped.com, select your scooter model, then click replacement parts and find the batteries on the part list.
Aug 02, 2010 | Go Ped Know Ped Goped Push Scooter
How do i change my driver side door my van is a 1994 plymouth voyager
first you go to local book store or dealer or ebay and pick up a chilton or haynes book it will come in handy for the wiring and the hinge torque and allinment specs and tricks
Jan 23, 2010 | 1994 Plymouth Voyager
My sliding patio door is sticking
usualy there are 2 ajustment screws at the bottom in the flashing
if you lift the door out of the track and look at the bottom you will see the rollers and likely the ajustment screws is there are no adusters make sure the rollers are free f not spray with penetrating oil and let sit untill free then try again
if sash or frame is tight try spraying it with pledge furnature polish the light grease coat will allow plastic parts to move freely once again
Jul 23, 2009 | Locks & Locksmithing
Stalling
Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
Apr 14, 2009 | Echo 3 TE SL7 3 New Electric Scooter by...
Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
Mar 16, 2009 | 2000 Honda Odyssey
2002 chevy silverado
fuel pump change required
Dec 08, 2008 | 2002 Chevrolet Silverado
Golden Technologies Companion II Travel Scooter Logo
311 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
