Question about Mag Innovision LT776s 17" LCD Monitor
Mag Innovission LT716 / 700P
Forgot the the order the wires plug in on the back of the monitor to the power supply or does it matter?
    New Friend:
  • 3 Answers
It does not matter since they are only the power feeds for the top and bottom back lights. You can plug either wire into either the top or bottom sockets and the lights will work just fine. Of course there is only one socket the data feed plug will fit into so that one is a no brainer. Next time you take something apart it's a good idea to mark the plugs or wires or you can even make a wiring diagram with a pen and paper.
Posted on Jan 11, 2015
The order the plug wires go is from the top right side - pink /blue
The bottom side - blue /pink
Posted on Feb 01, 2009
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
My lt865b doesn't display anything and the display functions of the monitor do not respond at all i love the monitor and need help.After 3hrs use the display starting going all white then blacked out. I...
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Mag Innovision InnoVision LT865s 18" Flat...
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
Feb 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Power-Supply Plug in on Monitor not present ?
wait, is there not a power port? if ther isnt, it may be on the vga port where it connects to the pc, it may of got cut off, your alternative is opening up the mointer and wireing a new power port
Aug 27, 2009 | Computers & Internet
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here:
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
The socket for the AC power supply is located RIGHT ON the cord that plugs into your tower/graphics card. I just bought one today at the thrift store, ** power cord, but was looking for the input myself and found it there. Hope that helps.
Feb 18, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Oct 07, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Mag Innovision LT776s 17" LCD Monitor Logo
450 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
