Question about AB Soft CTX 550 Multimedia Projector
Switching between video and computer.
I can't switch between the video input and the computer. Is there an easy way to accomplish this feat?
  • 2,237 Answers
Input on remote, or button panel.
Posted on Jan 29, 2010
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
My monitor says "no input signal" every time I put it on. I have checked all the wires and connections and they seem fine. Any suggestions?
Starting from the monitor and going to the video connection to your computer, make sure everything is connected and undamaged. If your video card has more than one output, try switching the cable to the other output. If neither is working, and the monitor works fine from a different computer, then its the video card, otherwise its the monitor. But again, before dropping any money on a new monitor, try a different cable, and try switching the cable to the second output if there is one. A video card is definitely cheaper than a monitor.
Aug 22, 2010 | HP Computers & Internet
When switching ford one user to another a input not supported
You get input not supported because the another user had set the video resolution too high for the monitor to display. Try looking into the resolution setting.
Mar 26, 2010 | Computers & Internet
No Signal after switching from digital input to analog vice-versa
What type of video connection is on the graphics card?
Test the monitor on a different computer to determine if the monitor is functioning properly.
Oct 06, 2009 | Acer X193W LCD Monitor
Not a problem just a question
You have to run the video files through the Philips Media Converter. I personally use Pinaccle Dazzle to connect the RCAs to my computer - use the Pinaccle software to capture the video - and then convert the VOB files to AVI format. Then, I can run the AVI's through the Philips Media converter. But this is not the only way to accomplish the feat.
-Tha Mp3 Doctor
Jan 02, 2009 | Philips SA3025/37 Flash MP3 Player
Want to listen to music while still watching football game
Some receivers with video switching have the option to stay on the video source when you switch to a different audio source, others don't. I have a Yamaha that will do this while my Kenwood will not because the CD and DVD input are one in the same. I guess it depends on what input you are using for your music input. If it's a DVD input it makes sense that when you switch the audio the video follows. Try connecting your audio source to an audio only input (say the CD input) and see if that will allow you to do what you want.
Oct 09, 2008 | Denon AVR-3803 Receiver
Yamaha HTR-5240 Receiver channels are mixed up
Sounds like your input switching IC is bad. THis is a shop job,major solder work and most likely a parts order. All the inputs tie into 1 intergrated circuit"ic" and the microprocessor see the signals and switches the output on this IC when you change inputs and when this IC goes bad you can have an outward symptom of not switching,only 1 input works or 2 or more inputs on at the same time. If this receiver cost several hundred dollars it's worth repair if less expensive unit you may want to look around for a new unit
Mar 07, 2008 | Yamaha HTR-5240 Receiver
AB Soft CTX 550 Multimedia Projector Logo
48 people viewed this question
Top AB Soft Office Equipment & Supplies Experts
jasbo
jasbo
Are you an AB Soft Office Equipment and Supply Expert? Answer questions, earn points and help others
