Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer LTF2140ES3
I am having error codes or a series of beeps and I didn't receive an operator manual that explains how to interpret and correct the issue. Can anyone offer help or a copy of the pertinent pages of the manual for this model? Thanks
  • Anonymous Sep 19, 2008
    door closes, light's lite up but, the sensor must be bad....cause the machine won't start
Go to frigidaire.com then to the manual section click on that manual and it will give you all the information you need. At least yours gives you the code, mine wont do anything!!
Posted on Oct 02, 2008
I need a chart showing the error codes for a front load fridgedair washer model LTF2140ES3
Hi Richard....Google - Frigidaire front load washer error codes.
There are several links with code listings. Try the Sears Parts
Direct link.
Regards,
Dennis
Oct 10, 2014 | Cars & Trucks
Frigidair front load washer FTFB4000FS1 wont start
Do you notice any alpha-numeric error codes or any audible beeps or sounds when you try to operate the unit?
Dec 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Front load frigidaire washer w/ error code F03....doesnt want to drain. Tried spin/drain, delicates, and normal and all end up with F03!! Please help!!! Thanks Royce
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Jan 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Lights come on and it beeps
The timer may be stuck, you may have to change the timer.
Apr 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
329 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
