Question about Saeco VIA Veneto Espresso & Coffee Maker
Via Veneto will not prime
I just bought a new Via Veneto online, it said it had been tested and was fully functional, but I cannot get it to prime. When I open the steam valve and turn on the coffee button, water comes out of the portafilter but nothing at all from the steam wand, not even a drip. I let it run through the full water tank a couple of times. I've read that these machines are hard to prime, but I just don't know what to do other than the same thing that doesn't work over and over. (who was it who said that one definition of insanity is repeating the same action and expecting different results?)
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Posted on Apr 14, 2009
Olivetti Praxis 35 Not Functioning
Bring this issue to the attention of the seller for clarification of "fully working".
Jan 17, 2014 | Olivetti Correctable film typewriter...
Our Porcher veneto 1 piece toilet does not flush. Does porcher have recommended repair service near zip code 94901 ?
I have three of these beautiful babies from when I redid my bathrooms back in the early 2000s -- and one of them started to leak (would keep flowing a small amount into the bowl after filling the tank), so I did some online sleuthing and came across the parts as well as the how-to for a complete rebuild of the critical parts -- and rebuilt all three and they work like new. I am in zip code 94552 so if you need help from a licensed general contractor -- give me a call at 510-909-8813 and I can see if I can fix it for you (for a charge, of course).
Sep 12, 2012 | Porcher Toilet Onepiece Veneto ...
Just bought the Olympus pen EP-L1 Im having trouble find lenses for my new toy any suggestions?
You don't state why you're having trouble finding the correct lenses, but they are easily available from online suppliers. Traditional retail outlets tend to stock very few of them though simply because there isn't sufficient demand to buy in and keep stocks of products which are constantly having updates and price adjustments.
You can use all Olympus Micro Four-Thirds lenses and most Panasonic Micro Four-Thirds (although to use some of the latter you may need to update the body or lens firmware.
Regular Four-Thirds mount lenses can also be used via an adapter but may not be fully functional.
Unlike other lens mounting systems, you can also get adapters to use almost any lens on Micro Four-Thirds system cameras, but the lens will typically have to be used in a fully manual mode with the aperture set fully open for composition and focus and then manually stopped down for metering and image capture.
Jul 12, 2011 | Cameras
I have the via veneto model that has the rubber tube that draws the milk in. It doesn't seem to build enough pressure now to do it. I have been cleaning and descaling it on a regular basis. The expresso...
Hi
There is a pin on top of the cappuccinator the will twist to create suction. Turn it slowly when steaming until it starts to draw milk up to foam. Then leave it. If you don't have the pin, thats your problem.
Jan 02, 2011 | Saeco VIA Veneto Espresso & Coffee Maker
Via veneto won't make coffee
I removed the top filter where the water comes out and cleaned it good with a pin for all the holes, then I did the same for the coffee filter. I found alot of the holes plugged which would avoid the from alowing the coffee to come out.
Now it works like new.
May 24, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
EXPLODING SAECO VIA VENETO
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Soggy Pucks & Portafilter retains water Saeco Via Veneto
It sounds like you are short on water due to a blockage somewhere...either in the flowmeter or the group head. You might also have a faulty pump, and you're not getting enough pressure during the shot. If you're not getting crema, then it's most likely pressure related...shots will also have a burnt smell and very bitter taste.
Mar 14, 2017 | Saeco VIA Veneto Espresso & Coffee Maker
Saeco VIA Veneto Espresso & Coffee Maker Logo
642 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
