Question about Brother HL-2040 Laser Printer
Connecting printer Brother HL2170 Laser Printer Installation:Wireless Setup and Driver Install/Step by Step/With Cable/Connecting Your device and access Point/ Gives Error finding devices, more than one wireless device was found./Available Wireless devices window is blank--it says to pick one, but there are none listed. When cable is connected into wireless hub (Westell 327W), the port it is plugged into does not light up on the hub. The cable seems to be OK, because when it is  used to plug in  another device, the port does light up.
1. Unplug the cable.
2. Hold the Go button for 10 seconds until the network config page is printed.
3. plug the cable and try it again.
Posted on Nov 07, 2008
Hi! I have a brother HL-2170W printer. It is connected via ethernet cable to a Dynalink RTA1046VW router (which is sitting on top of the printer) and I have a HP pavillion entertainment PC that is...
Your Printer is connected to the (network) router via ethernet cable. Hence, it is a NETWORK PRINTER NOT A WIRELESS DEVICE, no matter your PC is connected to the network wirelessly. So, search for and install the printer as a NETWORK PRINTER. From the printer installation, it should searh and find the printer and susequently install the required drivers.
Moreover, you may checkout the followings link for instructions on how to install/ add a network printer.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Apr 04, 2011 | Brother HL-2170W Mono Laser Printer
How to install brother hl-5250dn to windows xp
Fist uninstall all the drivers ralated to the printer, then install it again.
1. Turn off the computer
2. power cycle the printer
3. Turn On the computer
Aug 12, 2010 | Brother HL 5250DN Laser Printer
Where can i install brother hl-2040 laser printer
1st You download Printer Driver. Brother Laser Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 04, 2010 | Brother HL-2040 Laser Printer
Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Jan 26, 2010 | Brother HL-2170W Mono Laser Printer
I am unable to setup the wireless feature for my Brother 2170W laser printer. Any thoughts? ,<- is the link to the manual which explains in details how to configure the printer to connect to the wireless and how to install the printer on the computer.
Jan 23, 2010 | Brother HL-2170W Laser Printer
Does not recognize wireless devices when
You need to find out what antivirus program you are running then go to there website and find out how to make execptions to the firewall.
Nov 28, 2009 | Brother HL-4070CDW Printer
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Got a new laptop and need to connect the hp laser jet p3005
Hi Terry_preyse !!
Thank you for writing to
To setup a printer you'll require:
  • A Printer
  • An USB cabel or Wireless Card(if want to setup wireless printer)
  • Driver disc & it'll be shipped with the Printer
  • Last but not least, 15-20 minutes.
Unpack the printer carefully, plug the USB cabel in the printer. Don't connect it to the computer & turn on the Printer & here's what you need to do.
  1. Step 1 Set up your computer on your desk so that you are able to plug in your printer and other accessories in an orderly way. The PC is the center of your home office and all things should be setup in relation to this. Consider how you’ll run cables before selecting a location.
  2. Step 2 Assemble your printer. Few printers are ready to go out of the box. Open it up carefully and pull out the quick setup instructions. This usually entails affixing trays and installing toner and drums.
  3. Step 3 Decide on a method. Wired or wireless? Wireless will save you a lot of hassle but if you are on a tight budget wired does the job as well.
  4. Step 4 Install the drivers. Insert the CD that came with your printer into your computer and install the drivers before connecting your printer.
  5. Step 5 Connect with cables. Using a USB cable or a parallel cable, connect your printer to your computer. USB cables have a trapezoid shaped plug on the end that goes into the printer and a rectangle shaped plug that goes into the computer. Parallel cables will have holes on the computer end and pins on the printer end.
Hope this will help !
Anurag Shukla
Sep 03, 2009 | HP Hewlett Packard LaserJet P3005 Printer
Connect to wireless network
plug an ethernet cable into one of the ethernet jacks on the router and the other end into the printer. run driver installation setup on your computer that is connected to the wireless network and choose peer-to-peer networking. let your computer search for the network printer. follow installation instructions to complete.
you can download the driver here
Jul 29, 2008 | Brother HL-2070N Laser Printer
Wireless Setup
well..I suppose we should determine that you have your small office/business network set up first, right? it's under network connections. If it's not there, then your printer will stay invisible. Is this a replacement or new install?
Feb 17, 2008 | Brother MFC-8870dw Wireless Multifunction...
Brother HL-2040 Laser Printer Logo
468 people viewed this question
James Cagle
James Cagle
Jim Keysor
