Question about Motorola Mobility RAZR V3
Drains battery in 24 hours
My RAZR V3 burns through its battery in 24 hours on standby. 3 different new batteries did not solve the problem. I installed a known-good battery (from wife's identical RAZR). Same symptoms. Bluetooth is off.
  • guntherothk1 Sep 21, 2008
    The battery that came with my RAZR ran over 7 days on standby. Same with the identical battery that came with my wife's identical RAZR. The battery I removed from my wife's phone had run on standby for a week. Fully charged, my phone killed it in 24 hours.
    In fact, my phone will drain the battery even if powered down. That's not normal behavior. And before you ask, I can put the battery back in my wife's phone, and it lasts 7 days again. IT'S NOT THE BATTERY. It's a phone setting, or a phone defect.
    Anyone seen this? I wonder if some cases of alleged battery malfunction are like this.
  • guntherothk1 Sep 22, 2008
    Motorola's solution was "maybe the phone needs to be repaired. You can send it to us and for $75, we'll fix it." I guess in some sense this is a "solution", but it is as expensive as the solution of "discard your phone and buy a new phone from a different maker" but has more risks.
The problem is NOT the battery; rather it is a characteristic design flaw with the RAZR V3i (used on GSM systems) which Motorola will NOT admit exists and refuses to fix/replace without a fee (unless its in warrenty)..
Posted on Jan 16, 2009
  • 26 Answers
THE BATTERS ARE DESIGNED TO WORK ON STAND BY FOR ABOUT 3 DAYS BUT THE MORE YOU USE IT THE FASTER IT DRAINS TALK TIME ABOUT 18 HOURES CHARGE EVEY NITE SHOULD SOLVE THE PROBLEM
Posted on Sep 20, 2008
  • bigfoot71373 Sep 21, 2008
    the problem is not in settings you need to call motorola via land line at 1-800-331-6456
Motorola V3 does not hold charge. I have replaced the battery with 2 new ones. I have used 3 different chargers. Low battery indicator comes on after 4 hours even with no use of the phone.
Sounds crazy but have you cleaned the connection area for your battery? Don't use a lot of it but I use hydrogen peroxide to clean mine... just dampen the end of a q-tip and rub the terminals with it. If it fizzles, you have corrosion there... it won't if you don't. This also works for ANYTHING that uses a battery.
Dec 07, 2009 | Motorola Mobility RAZR V3
Brand new motorazr V3s. draing batteries. only 3 hours of use
HEY THOSE CHINESE CHARGER ARE NOT GOOD.. THEY SUM HOW NEVER CHARGE THE BATTERY PROPERLY ND THE BACKUP IS LESS. CHARGE USING UR MOTOROLA CHARGER ND IF U STILL EXPERIENCE PROBLEM THEN U BETTER GO TO MOTOROLA
Aug 16, 2009 | Motorola Mobility RAZR V3
RAZR V3 - New battery w/full charge drains in 1hr of standby
take out a battery and check if there is any red paper dots on the back of the phone. If you do have a dot that is at least partially red, that means that your phone got wet and it can not be fixed.
Nov 15, 2008 | Motorola Mobility RAZR V3
Charge
hi your battery has created a memory because you didn't follow simple battery guidelines:
For a new phone with a new battery;
1)Use the phone the first time until the battery dies,
2)Do a full charge - 6-8hours for the first time
3)Use the phone until it dies the second time
4)recharge the battery for 3-5 hours
then your battery should be good, but now your battery needs to be changed, as it already has memory and can only be restored if completely discharged by a battery conditioner
Jan 30, 2008 | Motorola Mobility RAZR V3
Battery
well...sir they do die quickly no matter the age of the battery......but you should buy a new one
Jan 26, 2008 | Motorola Mobility RAZR V3
RZAR v3 battery issue
Hi
try using until the battery is dead, then recharge for 24 hrs. let me know if it working so we can do other method
Nov 20, 2007 | Motorola Mobility RAZR V3
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Phone discharges battery
Well take it to the shop you bought it from and you might have to have kept the receipt and they will send it off to the specialists ,
it is a common thing with motorolas and batteries should last at least 1 year anyway hope i helped :)
Oct 16, 2007 | Motorola Mobility RAZR V3
Replaced Battery - Indicator Doesn't Work
probably the battery is not original and the phone does not reconize'it try buy an original one
Oct 27, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
182 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
