Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool dishwasher will not start
Whirlpool dishwasher series DU600 3381181. Now Dishwasher will not start, no lights. There is power to dishwasher connections. Dishwasher did not drain earlier so I pushed drain a few times and I got it to drain, so I ran it on hot cycle and it stopped without draining and not lights. Unhooked drain hose and drained it manually and closed door, nothing happens, no lights, no filling. Any ideas before I call the repairman? I have a whirlpool gu940scgq0 model dishwasher. She stopped working all together. Water at the bottom, though dishes were clean. No lights light up. So it stopped almost at the end of it's cycle. She is just dead. I've check the thermal fuse. Reads 1 ohm. The door switches have continuity when made and none when broken. So I think those are good also. Anything else to check before trying to replace the circuit board?. And is there a way of checking the board to see if it is good?
3 Suggested Answers
SOURCE: Whirlpool dishwasher will not start
I have a quiet partner I and it is doing the same thing!
I have only had it for 3 months. It did it once before, then after about a week, I tried it again and it worked fine?
I can't find my warranty anywhere. I bought it at Lowes.
Does anyone have any kind of solution? Looks like it is a common problem.
Posted on Aug 09, 2008
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
I have a whirlpool Gold series dishwasher that when I push the start button on my lights go out
Hello Cindy, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Dishwashers
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
I have a Maytag Quiet Series 300 dishwasher that won't start. There is power going to the unit, but the control planner was not function. please help.
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Dec 18, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Mar 11, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher -whirlpool
A series of tests that you can perform:
  • Check the door latch
  • Test the door switch
  • Test the timer motor
  • Test the selector switch
  • Test the motor start relay
  • Test the motor
  • If you found this helpful, Please vote. Good Luck!
    Mar 04, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
    Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
    139 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
