Question about Hoover Washing Machines
Ordered new washer handle no.ES544940 how do i fit?
Need to replace rubber on Grohe Ladylux Plus Pull out spray handle. How to get spray handle apart.
I bought DANCO "universal faucet pull-out spray hose - fits all facuet brands" from Lowe's, which came with all kind of adapter and the hose quality seems to be better than overpriced Grohe spray hose replacement (Grohe part # 46092). The only problem is that you may have to prepare a large rubber washer in order to the handspray (Grohe part#46298) as I don't see this large washer in the package but it is very important to fit in place to prevent water leakage. - Michael
Jan 13, 2012 | Plumbing
Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
I hope this helps.
Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
Installed new valve but when I screw the handle in I can't shut the water off completely. I can pull and turn the water on but when i push it in, it only turns off part of the way. To shut it off i have to...
On most moen single handle valves there is a washer that is supposed to fit over stem on cartridge.This washer has two flat sides to fit over flats on stem. The only other thing I can think of is that your valve face plate is mounted a little to far out and won't let back of handle go all the way closed. I would try tightening the two screws that secure face plate to valve a little and see if that helps. Good luck. Thanks
Nov 18, 2010 | Moen & One Handle Tub & Shower Faucet
Wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
How to replace a 2003 grand vitara's rear door handle
1. open the rear door
2. open the rear door sidings
3. try loosing the not of the handle
4. remove the steel wirings of the handle
5. install the new rear door handle
Jul 15, 2009 | 2003 Suzuki Vitara
Brass part in wand handle because the brass fitting
Bronze breaks, why it does not have flexibility. it substitutes part for steel inox
Jun 05, 2009 | McCulloch FH180A Electric Pressure Washer
Washing Machines Logo
76 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
