Question about Kenmore Oasis HE 27082 Top Load Washer
Piece if **** washing machine and dryer kenmore elite oasis
What a piece of garbage, we bought a kenmore oasis elite, suppose to be the best, after a year that we bought it , the pump had a hole , and the
F51 code came on, so we called a repairman, changed the pump, cost $85.00 plus service , then can't fix the F51 code because the part will cost $600.00 plus labor, so I said I rather buy a new one , he agree,now the freaking dryer is acting like a damn pissed of, just keep buzzing even i just turn the power, I am really mad , I want the kenore to give me my money back $1,940.64 , so I can buy a new one , I have a 3 years old and I need a washing machine, thanks mrs. olsen
  • Anonymous Nov 12, 2008
    This is the absolute WORST washer I have ever had. No one will be accountable for this terrible washer. First the control panel, then the power outage- because of the control board! don't buy it
  • 750 Answers
I called sears recall dept 1 888-548- 1509 told to make a service call about F problem and if that is the cause your charge for service call will be refunded and a new control board installed at known charge.The 27082 is not on the recall list yet but sears is aware of this condition.Don't give up just keep calling and ask that a copy of your call and complaint be forward to your address ,sears receives numerous call's each day about F1 control boards.
Cal them your self now and see if they will do this repair 1 888-548- 1509
Please leave a rating !
Posted on Sep 26, 2008
Kenmore Oasis Elite Washing Machine
dont overload machine and use fabric conditioner
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
My kenmore elite oasis washing machine stopped mid wash there is no power at all. Model #110.28092700
first plug a lamp or something you know works into the outlet.if lamp does'nt work,check the breaker at breaker panel.If that is not tripped,it may be the onoff switch,or timer on machine.
Sep 27, 2014 | Kenmore Oasis HT High-Efficiency 4.6 cu....
How can I reset Kenmore elite oasis he washing machine
You can download the manual at the link below but you need the model number. The site can also tell you where to find the model number. User Manual Downloads
Aug 03, 2014 | Kenmore Oasis HT 4.7 cu. ft. Top-Load...
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Door latch to Kenmore Elite Oasis gas dryer has come loose. It will not close properly in order for dryer to start. Need instructions on how to repair or replace latch piece on door.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
I need a manual for a Kenmore washer, model # 1102708604.
I have now got the manual for the Kenmore Elite washer and dryer coming in by mail. I had gone to the local Sears store and then to the service center close to home. The service center was able to find the manuals and order them for me.
Thanks for your help.
Cecil
Apr 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
356 people viewed this question
Sal De
fordexpert
Robert Rankin
