Question about Garmin GPS 12 GPS Receiver
Batteries leaked acid. How do I crack open to clean?
I left the the batteries in my 8 year old Garmin GPS 12 had the batteries leak acid. Can anyone tell me how to crack open the casing? There is a very small screw at the bottom of the unit but it seems to just hold the battery case lid. There is also a small hole in the back (under the rubber cover but a scre driver just goes right through. I can't feel a screw in there. I would like to open the unit and clean it out so hopefully it can still be used. I called Garmin Tech support and they said it was worth a try but no one could tell me how to disassemble the unit.
  • StillStrande Feb 07, 2009
    I have the identical problem.
  • 4 Answers
Just pry it open (gently) with a flat bladed screwdriver. It's glued together with silicone seal. To put mine back together, I scrapped thoroughly to get the old stuff off, crazyglued the corners, then later filled the gap with silicone sealer. Easy.
Posted on Feb 08, 2009
Yes, it is indeed glued along the edges. As someone else mentioned, very carefully pry the case apart along the indented line that encircles the unit.
I've got mine open now, but looking at the battery compartment, I might have to drill a very small hole in one of the tubes, to remove the battery that is stuck at the bottom.
Posted on May 31, 2009
Iread somewhere that it was utrasonic welded
Posted on Sep 29, 2008
    Scholar:
  • 147 Answers
Chances are it is glued shut, or if it's like a similar era Eagle Explorer, has two torx screws under the serial number sticker, and a gasket everywhere else.
Glue can sometimes be softened with a heat gun.
Posted on Sep 18, 2008
When on button is pressed the instrument panel flickers and goes off
Your Garmin device is probably over 12 years old. go get a new one. you have already gotten more than your moneys's worth out of this device. I recommend replacing it with an eTrex 20 or if you want a magnetic compass and better sensors an eTrex 30.
Otherwise, replace the batteries, open it up and replace any coin cell batteries in there as well.
Mar 26, 2015 | Garmin GPS 12 GPS Receiver
CAMERA
The only way to fix this problem, is to bring in to the place you bought it and see if they have a technician who can look at it or do it yourself.
I can tell you that whenever batteries are left in any battery operated device and corrosion happens, that corrosion will leak into the circuit board and destroy some of the components.
If you are lucky, you can open it up and clean it.
Just be careful when openning and do not use a solvent in it, unless it is one recommended for cleaning circuit boards by an electronics technician. The cleaners some technicians use are not even for electronic, but have been tested on delicate circuit boards and have been proven to be safe.
Ask someone like a geek at best buy or some other shop to find out what to clean it with.
Feb 13, 2008 | DXG Technology DXG DXG-301V Digital...
Duracell batteries leaked in my Garmin 62st.. New batteries too..
You can take the bad batteries out and clean up the battery compartment, using isopropal alcohol (rubbing alcohol and a lot of q tips). . Problem is if the acid wrecked the contacts. Light corrosion (green,corroded copper color) needs to be removed with sand paper or emery cloth, until all the contacts are shinny metal again. maybe spray some silicon on the newly shinned metal to slow down re-corrosion. If the damage is serious, i.e. the metal is eaten away, then someone with soldering experience needs to desolder the bad metal and resolder in good. This can be quite expensive is you take it to a technician.
Feb 23, 2015 | Garmin Gpsmap 62st Handheld Outdoor Gps...
I have a 4yr old Garmin GPSMAP 60CSx .that has ceased to function .Do you have the capability of working on this device
The on/off switch on these were problematic.. so you might want to look at the linkage and switch before digging deeper, below.
Corrosion is a problem. If you can clean it up, you should. If the corrosion is a result of a leaking battery, you should disassemble the device as far as possible to allow access to areas that have been contaminated with battery acid. I like to use a q-tip dampened in a mixture of baking soda and water (about 10% baking soda and 90% water). Battery acid conducts electricity and must be removed. Anywhere it is results in changes in the values of components and can cause a great deal of problems.
You may also be able to exchange for a modest sum with Garmin for one of their rebuilt units - if available.
Jan 09, 2015 | Garmin GPSMAP 60CSx GPS Receiver
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
Magellan gps 315 battery leaked and will not power up. what could be wrong
The acid from the leaking battery most likely shorted out the circuit board. You can trying cleaning of the acid spill with a little alcohol on a Q tip. The batteries are probably also no good and you will need to replace them also. If this does not work you can try taking the unit apart and cleaning any further acid that has leaked to the inside. Thanks for using FixYa
Here is a link to the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000013645.pdf
Jun 19, 2011 | GPS
I have a 8 year old garmin GPS model 12 that may be dead. When I turn the red power button on the garmin sez "upload not present". Also the rubber at the base near the batteries has rotted. Thanks for any...
I had the same problem and it took me some time to make my cable. I got this info from fix ya. Reload the software for your unit, I googled garmingps12 and went to downloads from the garmin selections.The software is not compatable with vista, so I ended up using my old computer to do the job. http://pfranc.com/projects/g45contr/assemb.htm
This web site gives good information on making your own cable.
I hope all works for you as it did for me. justaxiom
Aug 08, 2010 | Garmin GPS 12 GPS Receiver
My Garmin GPSmap 76CSx was working just fine. After leaving it unused for a couple months with a pair of alkaline batteries installed, I tried to turn it on. It would not come on. I checked the battery...
Try connecting it to USB and powering it up, to confirm that unit still works overall. You probably damaged battery connectors. Check if you can clean the connectors better, otherwise you may need to do some soldering to fix them, by yourself or n a repair shop. Check with Garmin if they have suggestions: a leaking battery should not disable a GPS.
Dec 10, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Hallo, Can anyone advise if an old Garmin 12 can be rescusitated if when turning it one all one casn get is a quick flash of the standard screen and then just a 'blue' screen?. (The batteries were still...
try putting fresh batteries in it and let it sit for 4 or 5 mins. then try to turn it on. mine did the same thing when i sat around for a year without being turned on.
Oct 31, 2009 | Garmin GPS 12 GPS Receiver
Garmin GPS 12 suddenly turns off
Stay clear of rechargeable NiCads as they supply to low voltage and you may experience cutouts ? Use good quality regular alkaline batteries. Check battery terminals in gps (both ends) for corrosion/rust and clean if necessary.
Dec 10, 2007 | Garmin GPS 12 GPS Receiver
Garmin GPS 12 GPS Receiver Logo
740 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
