I have a Potterton Puma 80E boiler which uses a Honeywell CM67NG control. My problem is that the heating comes on when I have not instructe it to ie. I set the time to come on a 6am I sometimes wake up in the night at say 3am and the heating is on. The min temperature is 5 degs which it hasn't fallen below in the house to cause the heating to come on. Why does it keep doing this and how can I fix it?
  • 579 Answers
SOURCE: loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Posted on Dec 31, 2007
  • 81 Answers
SOURCE: my aristion DIA 20-24 combi
just check your water supply of your aristion DIA 20-24 combi boiler if is in constant pressure. not properly circulated water supply can cause overheating.
and manuals can help us also in proper checking. at the link below please check this out if you don't have.
Posted on Nov 28, 2008
SOURCE: Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Posted on Feb 05, 2009
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
  • 43501 Answers
SOURCE: Hi. We recently moved to a rented property. We
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Posted on Nov 13, 2009
How to install wireless room thermostat to a potterton suprima boiler, do i connect to the programmer there is L&N then two more blue&yellow
Best way is to contact manufacture and get service manal and step by step instruction support and help from them or get online help from their website
Dec 07, 2013 | Honeywell Heating & Cooling
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
Feb 11, 2013 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Loud gurgling noises (air and water) from around the boiler and expansion tank (nothing from the rads/pump area) just after the heating is switched off. The system will not come on without a reset. The...
Could be a number of things, none of which can/should be done by homeowner. If unit was installed by a certified P&H installer, call them. They can fuss with warranty stuff and order parts. Also the Potterton Promax HE 24 is same as Baxi.
Nov 20, 2017 | Honeywell Heating & Cooling
CM67ng will not turn heating off
Are you running some type of program on the tstat??
Jul 06, 2017 | Honeywell Programmable Thermostat Heater
I have a Honeywell Thermostat CM67NG The flame symbol is showing on the thermostat, but there is no heat from radiators. The status code on boiler says there is ' no heat demand'. Boiler shows radiator...
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Nov 30, 2009 | Honeywell Programmable Thermostat Heater
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
Nov 13, 2009 | Honeywell Electronic Programmable...
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
Apr 04, 2009 | Water Heaters
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
