Question about Vtech Lands Phones
Parallel set on - Vtech Lands Phones
Fixed telephone compamy fixed it, low volage. thank you
Posted on Sep 19, 2008
Parallel port will not power up print server.
May be your parallel port is disabled in BIOS setup.
Enter BIOS setup (DEL key on some common boards, F1, F2, F8 or even F10 on some branded machines) to enter BIOS setup.
Use arrow keys, Enter key and Escape key to navigate through settings.
If Parallel port is disabled, press 'Page Down' button or '+' button (only one might work) to get an address for the parallel port.
Save BIOS and exit. Restart the machine.
Tell us the result.
Aug 30, 2011 | Tally Genicom 3810S Printer
What does parallel set on mean on a vtech phone
parallel i believe refers to the ability to use multiple handsets on one line and one call. This phone has the ability to isolate a telephone call so that only the original answering handset can tune into the conversation. If you only have one of these models then this setting has no real function.
Pls Rate This Post :D
Feb 11, 2010 | Vtech Digital Cordless Telephone VT-2568
I installed the laser hp 1100 on windows xp
Your problem is your PC parallel port is not configured or turned on. I would first look in the control panel, device manager and see if you have a parallel port listed and it does not have a yellow or red sign on it. If red or yellow then it is on but not configured. See below for that solution.
If it does not appear, reboot your PC and enter the bios. Find the setting for the parallel port and set to enable. If on you can change the setting on what type of parallel it is emulating. Normal is bi-directional IEEE.
Then save and restart to go into Windows. Test and print.
OK, if the parallel port in the DEVICE MANAGER shows a yellow or red sign on it, it has a bad driver, or bad settings. Un-install the port by right clicking and choose UN-INSTALL. Restart your PC and it should find the parallel port and install it again. Hopefully without the yellow or red sign on it. If the red or yellow sign is back. Look on the internet for the newest driver for your motherboard.
As a note: if you are using a print server or USB to parallel adapter these solutions won't help. You will have other issues to address.
Good Luck
Dec 17, 2009 | HP LaserJet 1100 Printer
What do parallel set on the phone mean
my phone has been stuck on parallel on for 4 days now and i cant remove i have removed battery unpluged entire phone for 12hours and still cant call out and no one can call me
Nov 02, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Cannot find vista drivers for my canon bjc-80, any help would be great.
Now that is a tall order. Finding drivers for a bubble jet printer. My best bet is that you'll need to contact the manufacturer of the printer and ask them if any such updates are available.
Vista do however have a large driver database.
Here is a link. Download and try. Do hope this help.
http://www.softwaredriverdownload.com/canon_bjc_80_printer_driver_for_windows_xpvista.html
Aug 17, 2009 | Canon BJC 80 InkJet Printer
FAULTY PARALLEL PORT ON ASUS P4P800-MX
can you try check what the bios settings for lpt1 are first?
You should have SPP or standard / ECP or EPP etc.
To flash your bios you will have to download the new bios and the flash utility from here for your model:
http://support.asus.com/download/download_item.aspx?product=1&model=P4P800-MX
Jul 06, 2009 | ASUS P4P800-MX Motherboard
Parallel dongle will not work with new system that only has USB connections
The dongle only works with a standard parallel port, not a USB parallel port adapter, It may be possible that a PCI parallel adapter card will work with the dongle. Check it first with the supplier and or software supplier of Designer 1.
Apr 16, 2009 | Computers & Internet
Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
May 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Slow printing
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Nov 01, 2007 | Canon BJC 80 InkJet Printer
Lands Phones Logo
868 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
