Question about Lexmark Office Equipment & Supplies
Cd rom does not work i need software installed to get the priter to work
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
ok if your cd room doesn't work try to replaced it
or try to used the cd in other dvd room and saved it to the flash drive
and then install it!!!!
Posted on Sep 18, 2008
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
My scanner is not working. Can't open HP director on my laptop. I tried to reinstall CD that came with it, but " more recent version installed" Printer and copier work fine.
Here are some diagnostics.
1. Go to control Panel and then to scanners & camera.
2. look for your scanner there.
3. if you find your scanner there try to scan from the wizard and you will be able to scan you docs.
To Reinstall the Hp Director....
1. first uninstall the HP director software using the removal utility located in your cd...
The uninstaller on the Internet is newer and works better than the one on the CD-ROM. Use this method only if the Internet version is not available. Follow the steps below to use the CD-ROM version only if you cannot get the regular uninstall to work correctly and cannot access the Internet:
  1. Leave the USB cable disconnected from the all-in-one.
  2. Insert the all-in-one CD-ROM into the computer. Cancel or close any installation windows that appear.
  3. Right-click the Start button, and then click Explore . This will open Windows Explorer.
  4. In the pane on the left, locate the CD-ROM drive letter that contains the all-in-one CD-ROM.
  5. There are two different versions of the software for some of these models. Use the file path that pertains to your version of the all-in-one software.
    • Early versions of the HP Officejet 6100 and PSC 2100 and 2200 series: Double-click the file hposcr01.exe , located in the Drivers\Uninst\language (ENU for English, ESN for Spanish, FRA for French, or PTB for Portuguese) folder of the CD-ROM.
    • The newer software version: Double-click the file Cleanall.bat , which is located in the Util\CCC\Cleanup folder of the CD-ROM.
    ONCE THE SOFTWARE IS COMPLETELY REMOVED.RESTART THE PC AND TRY TO INSTALL THE HP DIRECTOR SOFTWARE FROM THE CD.
Let me know for any further help....
http://www.ikarmatech.com
Sep 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Lost install CD for Canon PIXMA MP160
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error in installing wordtec webcam setup
THE SOFTWARE IS NOT VERY OK AGAIN OR YOUR CD ROM DRIVE LENS, SO WHAT YOU DO IS THAT GET ANOTHER NEW CD ROM OR DVD ROM DRIVE THAT IS OF HIGH SPEED AND DO THE INSTALLATION.
Nov 20, 2008 | Intel Motherboard
Install hp psc 1210
lost my cd for my printer hp psc 1210 where can I download for free
Aug 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Dvd rom detecting problem
You need to find what DVD reading and CD and also DVD burning software you had, then download versions of the programs compatible with Win 98--then they should work fine. Your CD/DVD drives will be ignored until you get the correct burning software installed. Go t Samsung, which hopefully will have the appropriate downloads for Win98. If Samsung no longer has what you need, find any software for Win98 such as Roxio, or hopefully freeware, and you should be back in business.
Feb 12, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Priter
You can download the software here from Canon. Pick XP as your OS. After you download the XP driver and software you can install your printer.
Jan 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Model 4476-k02 serial # 22340443041
My Lxmark priter model is 4476-K02 and S.No. is 23385587803 2003/09. I Cant Use It.Because I hav'nt CD to Install It.
Nov 04, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Dvd - cd rom wont work
Dear friend, In your system cdrom drivers currupted for that drivers you need to install a mscdx file in drive "c" then it works fine.
Dec 14, 2006 | LG CRN 8245B (CRN-8245B) Internal 24x...
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
