Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Cannot open rear door
I'm trying to clear a paper jam in my C4180. The manual says to "press in the tab on the left side of the rear door to release the door." I have pressed, pushed, pulled and yanked the tab, but it does not want to move. I have two C4180 units, and neither tab is cooperating. I then tried to pry the door open, but it seems completely sealed from the evil end-user.
Any suggestions?
I figured it out! I yanked the tab to the right extremely hard, thereby opening the door. Obviously, "press in the tab" was incorrect in HP's manual.
Posted on Sep 19, 2008
Paper jam c4100 photosmart printer
Step 1:
Step one: Remove any loose paper
Step 2:
Step two: Clear the jam from the All-in-One
CAUTION:Clearing a paper jam from the front of the product can damage the print mechanism. Gain access to and clear paper jams through the rear door whenever possible.
Step 3:
lear the jam from the back of the All-in-OneFollow these steps to clear the jam from the back of the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Press in the tab on the left side of the rear door to release the door. Pull the door away from the product to remove it.
Step 4:
  1. Gently pull the paper out of the rollers.CAUTION:If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
  2. Replace the rear door. Gently push the door forward until it snaps into place.
  3. Connect the power cord to the back of the product.
  4. Press the OK button to continue the current print job.
Mar 18, 2013 | HP Photosmart C4100 series
Paper is always jamming
Clear the jam from the back of the All-in-One Follow these steps to clear the jam from the back of the product
    1. Gently pull the paper out of the rollers. CAUTION: If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
      Clear the jam from the front of the All-in-One If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front. CAUTION: Remove the paper jam carefully because it is possible to damage the product when removing paper from the front.
      2. If necessary, pull the input tray down to open it, and then lower the print cartridge door.
        1. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams might occur.
        2. Close the print cartridge door.
        4. On the control panel, press the Start Copy Black button (c01495311.gif ) to continue the current print job.
          Step three: Perform a power reset Follow these steps to reset the product.
          1. Press the Power button (c01602202.gif ) to turn on the product.
          2. With the product turned on , disconnect the power cord from the rear of the product.
          3. Unplug the power cord from the wall outlet.
          4. Wait at least 15 seconds.
          5. Plug the power cord back into the wall outlet.
          6. Reconnect the power cord to the rear of the product.
          7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
          Step four: Clean the rollers
Mar 30, 2011 | HP Photosmart C4180 All-In-One InkJet...
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
My hp laserjet 2430 keeps showing paper jam on tray 2 but no paper jam there. I have to press the ok button always to proceed. what could be the problem
Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the rear of the product.
    Remove the rear access door. Press in the release tab on the rear access door, and then pull the door away from the product. Figure 2: Remove the rear access doorc00909313.gif
  • Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them.
    CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
  • Check the rollers on the rear access door. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  • Open the cartridge door.
    Without turning off the product, disconnect the power cord from the back of the product.
    CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  • Disconnect the power cord from the wall outlet.
  • Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    NOTE: You might need a flashlight to illuminate areas for proper viewing.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove all traces of paper or obstructions found.
  • Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.Close the cartridge door.Reconnect the power cord to the back of the product.Reconnect the power cord to the wall outlet.Press the Power button (c01602202.gif ) to turn on the product.
  • Nov 11, 2010 | HP LaserJet 2430dtn Printer
    Printer says to clear paper jam and press OK there is no paper jam
    If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not
    in the rear rollers, check the top door.
    To clear a paper jam from the rear door
    1. Turn off the HP All-in-One.
    2. Press in the tab on the rear door to release the door. Remove the door by pulling it
    CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
    damage the print mechanism. Always access and clear paper jams through the
    rear door.
    Page 148 of manual here will show you more info as well as photos on hoto.
    If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
    May 01, 2010 | HP Photosmart C8180 All-in-One InkJet...
    Printer can't receive 250gram photo paper. I get
    If you put your hand inside there will be a paper picking Roller (rubber) clean them with the spirit ..
    or with the wet Towel ..
    which will solve your issue
    if still not then follow the paper Jam steps - cleaning the rubbers when you open the rear
    1. Turn off the product and unplug the power cord.
    2. Turn the product around to access the back of the product.
    3. Open the rear access door:
    1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
    2. As the door shifts to the right, pull the door out slightly to release.
    3. When the door is released, gently remove the door by sliding the door out and to the left.
    4. From the rear access opening, gently pull the jammed paper out of the rollers.
    NOTE: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. If all the pieces of paper are not removed from the product, more paper jams are likely to occur.
    5. Replace the rear access door:
    1. Insert the two posts on the right of the door into the holes on the right side of the opening.
    2. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    3. As the door shifts to the right, push in the left side of the door to lock it into position.
    6. Reconnect the power cord and turn the product on.
    Jan 03, 2010 | HP PSC 2355 All-In-One InkJet Printer
    How do I open the 1610 printer to fix a paper jam?
    Press in the tab on the left side of the rear clean-out door to release the door.
    Remove the door by pulling it away from the HP All-in-One.
    Caution Trying to clear a paper jam from the front of the HP All-in-
    One can damage the print mechanism. Always access and clear
    paper jams through the rear clean-out door.
    2. Gently pull the paper out of the rollers.
    Warning If the paper tears when you are removing it from the
    might be remaining inside the device. If you do not remove all the
    pieces of paper from the HP All-in-One, more paper jams are likely to
    occur.
    3. Replace the rear clean-out door. Gently push the door forward until it snaps
    into place.
    4. Press OK to continue the current job
    Oct 25, 2009 | HP PSC 1610v All-in-One Printer
    Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL...
    Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
    1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
    2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
    3. Replace the rear door. Gently push the door forward until it snaps into place.
    4. Press Cancel to continue the current job.
    Clearing a paper jam from the front door
    1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
    2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
    3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
    4. Press Start Copy Black or Start Copy Color to continue the current job.
    Aug 06, 2008 | HP Office Equipment & Supplies
    Paper jam
    Fiend your solution direct from hp. Here is your solution...
    http://www.hp.com/printer/prob676ijt65/solution
    334
    Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
    HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
    102 people viewed this question
    Ben Johnson
