Question about Apple iPod MP3 Player
I Can't unlock my Apple Ipod (black)
My grandson locked my ipod and for got the code
I need code
Posted on Mar 04, 2009
  • Apple Master
  • 19,396 Answers
On MAC :
  1. Enable hidden folders.
    If you go into Terminal and run these two commands all the hidden files appear when you open Finder.
    defaults write com.apple.finder AppleShowAllFiles TRUE
    killall Finder
    To get back to hiding hidden files use these commands
    defaults write com.apple.finder AppleShowAllFiles FALSE
    killall Finder
  2. Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
On Windowsç
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
Posted on Sep 18, 2008
2 Suggested Answers
  • 14 Answers
SOURCE: forgot screen unlock code
For those forgetful people
all right guys i have a solution for this but it will require some work first:
  • Mount the nano (plug it in)
  • Navigate to X:\iPod_Control\Device\ (where X is the drive letter of the iPod)
  • Find the file called "_locked" and open it with Notepad or TextEdit
now u should get some thing like : Vôáijåö\féúPbíþT~ñâHzõæLvùê@rýîD as the text but its not that con fusing to show here are two diffrent codes
the same!
]óãhjåö\féúPbíþT~ñâHzõæLvùê@rýîD
so in fact the part that matters is the first 4.... and its a 4 digit code!!
soooo i have made a guide line.. for u to match up your code with
0000
^ðàk
1111
_ñáj
2222
\òâi
3333
]óãh
4444
Zôäo
5555
[õån
6666
Xöæm
7777
Y×çl
8888
Vøèc
9999
Wùéb
now how does this help ?? well i set my code as 1234 and this is what the first 4 digits were: _òão
if u look at the first one and compare to the guide it shows that the first digit is 1 the second 2 the third 3 and the last is 4! taaa daaaa!!!!
Rock on people hope this helps!!!!
~Thimolas the awesome :P
oppps!! forgot to mention that eagle btc helped me find the folder...... the little bit at the begining was from
http://forums.ilounge.com/showthread.php?s=&threadid=118446&highlight=combination+lock
Posted on Mar 11, 2009
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
Apple ipod password mistake how is unlock the 30gb apple ipod
Hi bashamdbasha
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.
Please take time to rate me
Bud
Oct 07, 2012 | Apple iPod MA446LL/A MP3 Player
Black ipod classic 80gig. how do i reset it,ive forgot the 4 didgit lock code?
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
Dec 27, 2010 | Apple iPod classic MP3 Player
My grandson somehow put a code into my ipod nano and it's locked - he doesn't remember the code - how can I unlock it?
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Sep 15, 2010 | Audio Players & Recorders
My gradson forgot the code to unlock nano
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Taker care.
Jun 04, 2010 | Apple iPod nano
Forgot lock code for ipod 8gb grandson lockd it and doesnt remember the code to unlock it
Mar 06, 2010 | Apple iPod nano
How can i unlock my ipod after my lilttle brother changed it
Your question was cut off but I think you were about to say that your brother set the lock code. By plugging the iPod into a computer itunes should unlock it automatically. If it only unlocks on the computer, you will need to restore your ipod which will rid you of all your music. I hope you have back ups.
Aug 27, 2008 | Apple iPod MA446LL/A MP3 Player
Unlock my apple nano ipod 2gb
my ipod asks me to enter a code and i dont know it
Dec 01, 2007 | Apple iPod nano
Apple iPod MP3 Player 30GB
Wow sorry to hear about that :: Here is the info you need :: According to Apple, if you have forgotten the code, you can unlock the iPod nano or iPod by doing the following: Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data." I hope this helps
May 07, 2007 | Apple iPod MP3 Player
Apple iPod MP3 Player Logo
128 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
