Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Something chewed up
My wife said it started making clunking sounds,02f error. I found that the front of the inner tub moves up and down about an inch. It did not fully drain. Checked the drain strainer underneath and it was chock full of what looked like ground up particles. Some long thin plastic strips also and a couple of these strips around front lip of inner tub. No water was leaking out onto the floor. Whatever holds the front of the inner tub up is no longer there.
    Novelist:
    Champion:
  • 261 Answers
What you have is called spider failure. This is the three spokes that connect the basket to the spindle. The plastic is shavings of your tub.You need to get the rear of the tub replaced and the basket replaced.
Posted on Sep 30, 2008
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
Yesterday my ge wcvh626ohww washer was running through a spin cycle and I heard a (excuse my noise descriptions) thump like something broke loose, and it sounded like the drum was spinning very unusually...
I don't have experience with this particular machine but it sounds like it might be the drive belt. The following website might shed some light,... has videos. There are also sites which show parts diagrams.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-3-862537-/GE-Washer-won-t-spin-WCVH6800J1WW
Hope this helps a bit.
Mar 26, 2017 | Washing Machines
My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum.
Welcome to FixYa.
Based on your description "My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum"
my first suspicion would be a worn tub bearing, unfortunately all too common with those Frigidaire.
The tub bearing is likely worn, or the inner tub has broken apart.
You can check this by way of opening the door and grabbing the inner basket rim and moving up and down to feel for play...there should be zero play or zero tolerance in this bearing.
Second, since you`ve removed the back panel, grab the large pulley and try and move it back and forth or spin it with the belt off to listen for a grinding noise.
If it is indeed worn it will require practically the complete tub assembly ( rear wall with bearing and inner basket )...that is the least expensive and easiest fix at around $400 for the entire assembly.
example...
You can opt to change just the rear wall and bearing with the basket in separate pieces, but it comes in around $370 and still leaves you with pulling the old one apart to re-use the front shell.
Either way this is a fairly involved repair and even for an experienced tech like myself can take 60 - 90mins.
Let me know what you find and I'll do what I can to assist you.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Sep 29, 2010 | Frigidaire FWT449
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
My Miele Novotronic W1918's drum is moving forward and scraping on the door glass. It is also making a clunking sound when washing.
sounds like your inner tub is broken. check your manual for the warranty. if there is no coverage left be prepaired for a hefty bill
Feb 07, 2010 | Miele Novotronic W1918A Front Load Washer
Washer clunking
Look just inside the door. Between the door and the tub. Feel around behind the rubber boot that seals the tub to the door. See if you find a bic lighter, pocket knife or something like this.
Please rate solution if helpful
Aug 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-FoldĀ® Projector...
Maytag Neptune Washing Machine
can you reach inside the unit and grab tub and lift it up(as if perhaps the rear shaft has loosened causing more then a 1/4 inch of play in inner drum??? if that s the case sounds as if perhaps you have a bad rear bearing (over $700 in parts alone)
Dec 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
He2 washer flashing code f51
I agree with sissssss. For my Maytag's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
* Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool (Lowes 403255) below to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS mess.
Dec 03, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
102 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
