Question about Electrical Supplies
Household wiring Two way switch wiring diagram when power runs directly through switch commons run through connector strip outside of switch
  • joanyvonnegr Oct 04, 2008
    two-way switching wiring
    Problem Solver:
  • 5 Answers
There are 2 3way switches. Usually one end has a wire going to the light, and the other end 3 way switch has the always on power coming in. Between the two switches are 2-wire travellers.
On the actual 3way switches;
2 screws are the same color and the 2-wire travellers go on these. The other screw is a different color -usually black. This screw gets the power on one end, and the switch leg to the light at the other end.
Posted on Mar 14, 2009
  • 4,234 Answers
FIrst of all, it is actually called a 3-way switch system. I would suggest that you either consult and elexctrician or look up the Time-Life series on home projects which contains a couple of volumes on electrical projects. Included in there are complete diagrams of how to hook up 3-way switch systems.
Dan
Posted on Oct 07, 2008
I have power from wiring harness on outside mirrors. No power coming out of connector. need color wiring diagram on 2003 F150
Haynes manuals will have the information they run around $30.00 any auto part store.Good Luck.
Aug 03, 2016 | 2003 Ford F150 Regular Cab
Can I run a wire off of the rear brake light stop switch when the pedal is pushed in and run the wire to the back of the car directly back to the the wire before it gets to the bulb?
have you got the switch set accurately ? to test the wiring from switch to lights bridge the contacts in the connector that plugs into the switch , a piece of auto wire stripped at both ends will do , if the lights come on then the switch is the issue , just needs setting properly, screw it out a little at a time as the pedal needs to release the switch for the lights to come on
Jul 01, 2014 | 1998 Chevrolet Lumina
2006 FXSTDI NO POWER TO COIL
Hi Anonymous, with a test lite check continuity at ignition switch and run stop switch. Check ignition circuit wires, connectors, connector blocks, ect. For a free wiring diagram please visit website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Mar 05, 2014 | 2003 Harley Davidson FLSTC Heritage...
I have a haier household freezer model #hncm035e replacing thermostat controller that connects to temperature control and two lights one red for power and one green for running. I do not remember how wires...
I could only find a diagram on a you tube video. Look for Haier Freezer Repair posted by marcibm1. He took a picture of a freezer wiring diagram just like yours only it is a bigger cu. ft. Yours is 3.5 and his is a 7.0. After you study this, if you still have issues, let me know. First thing is to determine what wires go to the indicator lights. Usually the large black wires are power in and out of thermostat to compressor. Take your time and study the diagram. Let me know if I can be of any further help.
Mar 07, 2017 | Haier Freezers
I want to know to to install my kill switch nothing wrong with it and to know we're to put where it belongs
A kill switch is an effective and economical way to dissuade a thief from taking your car. While it may not prevent a professional thief from stealing it, it will likely deter the average amateur. The key to how to install a kill switch is the choice of what type of switch and where to place it. A kill switch that controls the power to you fuel pump is far more effective then a regular battery kill switch, because it is unexpected and can be well hidden.
Difficulty:
Moderately Easy
Things You'll Need:
Wiring diagram for vehicle Electrical tape Toggle switch Drill Phillips head screwdriver #14 wire Inline fuse Wire crimping pliers (2) **** connectors (2) Post connectors (type dependent on switch)
Instructions
Park your car on a level spot with the parking brake on. Raise the hood and disconnect the battery cable.
Use your wiring diagram to locate the power wire for your fuel pump. Make sure this is the power wire and not the ground by following the wire to the fusebox (or ignition). The ground will terminate to a connection to the frame of the car. Place a 'tag' on the power wire under the dash with a piece of electrical tape so you can find it again easily.
Open the package to your toggle switch and remove the mounting bracket and hardware. Follow the directions to mount the switch under your car's dash, or on the body of the driver's seat. You will need to use a drill if you do not have pre-drilled holes for the mounting screws. Make sure the switch is tightly installed by pressing firmly into the screws with your Philips Head screwdriver and turning it clockwise until it is hand tight.
Cut the power wire to your fuel pump with the middle section of your electrical crimping pliers.
Cut two pieces of #14 wire long enough to run from the back of the kill switch to the cut power wire.
Strip the ends of the cut power wire and both ends of each piece of #14 wire. Use **** connectors to connect a #14 wire to each of the ends of the power wire. Crimp the **** connector closed over the joined wires ,and pull lightly to make sure the connection is solid.
Attach the wire connectors to the bare ends of the two pieces of #14 wire (style will depend on the connectors of your toggle switch), crimp into place and tug test again.
Connect the #14 wire that joins the power wire that goes into fusebox or ignition box to the connection on the toggle switch that is above the base of the toggle (there will be only two connectors on the back of the switch; do not use the 3 post kind, as that is a lighted switch and easily found).
Connect the remaining #14 wire to the switch. Re-connect the negative cable to the battery and test your switch, make sure you can hear the pump come on, and you are done.
Tips & Warnings
Re-wire any accessories that need constant power (like the clock, radio or any other anti-theft devices you have) directly to the battery.
Never do any work on any electrical component of the battery without first disconnecting the negative cable on the battery; if it remains connected, you run the risk of a shock or fire while working.
References
Kill Switch
Feb 23, 2013 | Motorcycles
Simple horn diagram for 19ft. ski boat
One lead is power when button is pushed the other ground.
Jul 26, 2012 | Boating
Power antenna motor won't stop running. Do you know where the cutout switch is located?
There is no switch. When the plastic gears inside the power antenna strip out they continue to run because the limiter switch inside the unit never gets tripped. If you can assist the antenna up when it's running, leave it up and disconnect the power to the motor. If i remember correctly the antenna is mounted on the passenger rear quarter panel. You should be able to pull some of the truck trim out a little and disconnect the two or three wire connector.
Jul 08, 2010 | 1993 Buick LeSabre
Need wire diagram how to install 3 N 1 start relay on a true t12f freezer
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
Apr 29, 2010 | True 12 cu. ft. / 340 liter Commercial...
I need a diagram for home wiring, 2 gang switch and a 3 way switch.
A two gang switch will be a swith witho the the shape of a duplex outlet. with a toggle on each end. there will be two screws on each side with possibly a green screw on one of the sides. The green screw is for ground, and should be either attached to the box or a green wire all the way back to the panel. The screws on one side will be a copper brown color and you will notice a strip of metal that connects the two screws together. This is the hot or common side (usually a black wire. The two screws on the other side will be a bright copper color, and they will be the swich leads from the switch to the fixture you are attempting to power up (the wires that connect to these switch leads are probably any color but green or white). Never connect the neutral (white) wire to any part of the switch.
The three way switch will have three screws on it. One is copper brown, and the other two are bright brass in color. The dark screw is the common (black wire). the other two screws connect the runners from one switch to the other switch. The runners dont connect to anything but the other switch. On one end the common wire attaches from the switch to the power and on the other end the common wire attaches from the switch to the fixture. The white (neutral) wire does not connect to the switches, it runs from the panel directly to the fixture.
I hope this has been helpful.
Mar 25, 2010 | Gb Electrical GSW-117 Toggle Switch
Electrical Supplies Logo
1,129 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
