Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak aio printer 5300/software problem
My problem is the software that came with the printer can not download onto my computer (windows xp) coming up with error codes everytime the download gets to the Microsoft.Net Framwork part of the download. Then I get a error message that a setup package could not install.
  • 1 more comment
  • jimmyad232 Sep 24, 2008
    I have the aio icon but when I try to access it all I get is an error box.
    I can get to it by easyshare but the colours are all wrong in the photo's.
    I have only had the printer for 1 month and am very dissapointed.
  • jimma718 Jan 16, 2009
    it wont download and if one time it did and when tried to print something, it ask me to turn on my printer?
  • willieandpoo Jan 16, 2009
    dOES THE WINDOWS WORK WELL WITH WINDOWS VISTA SINCE I ADDED PRINTER I HAVE TIMES WHEN SCREEN FREZZES COULD IT HAVE TO DO WITH NEW PRINTER? I HAVE DELL. MARCY
    Problem Solver:
  • 19 Answers
Greetings Jackie,
Sounds like you have a failed .netframework installation. This is a Microsoft feature, but is delivered during installation of Kodak software as well. To fix this, do the following.
1. Open the Control Panel.
2. Double-click Add / Remove Programs (Windows XP only).
3. Select Microsoft .NET Framework 2.0.
    IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove.
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
    1. Follow steps 1 - 4 above.
    2. Select Uninstall, and click Next.
      IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
    3. Restart the computer.
    4. Perform a clean re-installation of the KODAK AiO Home Center software:
      a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
      NOTE: Do not disconnect your mouse or keyboard.
      b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
        i. In the Control Panel, select Add or Remove Programs (Windows XP).
        ii. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
          • Kodak EasyShare software
          • Kodak all-in-one printer software
          • Kodak EasyShare 5000 series all-in-one software
        iii. Click Change or Remove (Windows XP).
        iv. When the Install Wizard appears, click Next.
        v. Depending on the issue(s) you are experiencing, do the following:
          • If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
          • If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
        vi In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
        vii. In the Ready to remove the program window, click Next.
        viii. In the Uninstall Complete window, click Continue.
        ix. Restart the computer.
      c. Delete the files and folders that can interfere with the installation:
        • Printer folder in C:\Program Files\Kodak
        • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
        • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
        • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
      d. Run Disk Cleanup.
        i. Open My Computer.
        ii. Right-click Local Disk (C:) and select Properties.
        iii. Click the Disk Cleanup button.
        iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
        v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
        vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
      e. Shut down all background applications.
        i. Select Start > Run.
        ii. Type msconfig in the Open field, and click OK.
        iii. Select the Startup tab.
          IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
        iv. Click Disable All , then click OK .
        v. When prompted, restart the computer.
      f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
      g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
      h. Before restarting the computer again, turn on the background applications.
        ii. Type msconfig in the Open field and click OK.
        iv. Under Startup Items:
          - If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
          - If all background items were originally selected, click Enable All, and click OK.
      i. Restart the computer.
      Once restarted, you should be OK.If not call our 800 421 6699 and they will help further.
      Best Regards,
      Ron Baird - the friendly Kodak guy
Posted on Sep 22, 2008
Able to download the exe file obtained online onto
Have you tried to restart your computer?
Is the error only appears to this software?
Did the file came from HP's official site?
That file might be corrupted
try to download the file again
Feb 26, 2010 | HP Photosmart 7850 InkJet Printer
I'm having trouble scanning a document. It comes up with an error that thereis no communication. It does print??? Any ideas?
clarification please. well sometime and i chance usb port and it works. or restart your computer. there should be a software that you download onto your computer that comes with the printer. you should open the software everytime you scan/print something.
Feb 12, 2010 | Canon MX700 Office All-In-One InkJet...
Error while unpacking program, code LP5.
This can be caused by many reasons,Please post computer an installed software details,This is usually caused by an antivirus program or a virus but can be caused by any downloaded or packaged software
Jun 07, 2009 | Microsoft Windows XP Professional SP2
Softwear to install on my computer to connect my printer
Go onto www.hp.com choose the download option and then type into the box, Officejet 6310. Choose the option for your operating software i.e. XP, Windows 2000 etc, and download the software onto your pc.
Regards
Alan Hood
ami-man
UK
Mar 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Cant get past cd installation
Grab the software from Sandisk's website and try again. If that fails, upgrade your XP to SP2 or 3.
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
%1 is not a valid WINn32 applicationn
Software cd is bad and that is why you are getting this error message. The best solution is to go to Hp website and download the software
If you have Windows XP than go to following link
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=421991
If you have windows Vista than go to following link
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=421991
Regards,
Lalit
Sep 06, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark p3150
click here and select your windows version
thanks for rating
Jan 15, 2008 | Computers & Internet
Cant download kodak easyshare software
If you have a firewall up, disable it than try to download the software.
Sep 20, 2007 | Computers & Internet
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
1,247 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
