Question about Gestetner DSm645 Digital Imaging System
Gestener C764ond Hello, how do I change the waste toner bottle.
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'll have to look this one up.  Some models recycle the toner.  Some do not.  Do you see a plastic bottle in front of the door in front of the copier?
    Master:
    Sergeant:
  • 449 Answers
Maybe yess!!
but the your copier will not print original one
you use a bukl toner so the copy of it is lighter than the original one
Posted on Sep 18, 2008
Lexmark c 925 reset waste toner bottle
I don't know if you got an answer to this but I found it in the Menus>Supplies menu>Replace Supply and then tick yes for waste toner bottle replaced.
Mar 03, 2014 | Lexmark C925 X925 WASTE TONER BOTTLE
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Waste toner box full message after changing the waste toner box
When you removed the waste toner bottle, there is a sensor inside the copier. When you remove the waste toner, look to the opening where the top of the waste bottle was, clean that area and return the bottle and turn the copier OFF then ON. Good Luck
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
We have a replace the toner waste bottle message (14) on a Panasonic 350 . How do you replace and where is the waste bottle?
Hello sir; If you face to the machine on the down right corner have small door open the door you will find the waste toner bottle.
Aug 14, 2009 | Office Equipment & Supplies
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Apr 14, 2009 | Canon imageRUNNER 2270 Copier
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Apr 10, 2009 | Lanier Office Equipment & Supplies
Gestetner DSm645 Digital Imaging System Logo
77 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
